I recently purchased the U7185 for my LLY and was wondering if I need guages to run the tow tune when towing my race car for monitoring egt? Also, would I need guages to run the standard tune for daily driving? My truck has a 4 inch turbo back performance exhaust and the turbomouth piece mod.
Thanks,
Patrick
05 LLY Standard Tune
Re: 05 LLY Standard Tune
No worries.
Only time you'd need to consider monitoring EGT is with the performance or extreme tunes, the tow tune is fine up to max tow rating, and the economy tune will run great as long as you do not pull with it.
I just purchased an egr blocker plate so how can I tell if my programmer will clear the code thrown from the plate? I have an older predator I'm sure.
it will clear the code, but not disable it...
Older versions can disable it, newer ones cannot.
How can I tell if mine is an older one?
what is the version on the top line of the main menu?
thats older, should show them.
