ACTUAL GAINS!!!
eric.hauptman
ACTUAL GAINS!!!
I'm posting this to see what people have noticed in actual gains from there stock tunes from the diablo tunes
I have not had the oportunity yet to do a dyno to get true figures however this is my test and results, using the trinity t-1000 I used the virtual drag tree to do a 0-60 and a 1/4 mile 2 times on both my stock tune and using diablo's 91 oct tune and seen only .5-.6 sec. faster in the 0-60 and a gain of 1.1-1.2 sec. faster in the 1/4 mile with a gain of 5-6 mph faster in the 1/4 mile.
Trinity T-1000
2011 Dodge Challenger R/T
Magnoflow Exhaust
K&N CAI
Trinity T-1000
Magnoflow Exhaust
K&N CAI
Re: ACTUAL GAINS!!!
'only' .5-.6 off 0-60 and a full second in the 1/4 mile?
Those are HUGE gains, a 5-6 MPH improvement would equate to about 50 rwhp being added
Re: ACTUAL GAINS!!!
I will be playing with car this weekend...
I will post my results..
My Stock to Rock Pictures
http://www.jamcarclub.com/showthread.php?t=18
Re: ACTUAL GAINS!!!
We were out last night at North Star Dragway near Denton Texas north of Dallas Ft Worth. Unfortunatly it was very busy and did not get a decent cool down run. It went 8.84 at 79.70 with 2.05 60 stock with no tune but car sat 1 hour before this run. Best with 93 tune and hot car was 9.08 at 77.91 with 2.11 60.
Car is a 2011 Charger R/T 5.7 track pack with 3.06 gears. Car had little over a 1/4 tank of 93 octane in it.
Did some data logging. Had some knock readouts ST highest from 4.40 lowest to .50.
Car was almost hot lapping so times don`t bother me. DA was around 1800` and temps were 72.
Tonight we are going to Texas Motoroplex 1/4 mile south of Dallas to do some more runs. This time cooling it down up to an hour before passes. We will be lucky if we get 3-4 in.
We wanted more gains but understand with a hot car we are wasting our time.
Impressed with the throttle booster settings and shift firmness setting and all the data logging that can be accomplished. Thanks again Diablo for getting this car unlocked. I know this car has more in it.
I will post lots of info this weekend.
Re: ACTUAL GAINS!!!
I have to imagine its knocking a lot to lose 2 MPH in the 1/8, try adding some fuel to the tune
Re: ACTUAL GAINS!!!
thanks for the reply mikel.. I will try adding some fuel.. I have never done that before but looking at the forums I have some idea. If you go too much fuel it will just be too rich and slow down I assume?
Re: ACTUAL GAINS!!!
WHat do you have ur throttle booster set at?coair73x wrote:thanks for the reply mikel.. I will try adding some fuel.. I have never done that before but looking at the forums I have some idea. If you go too much fuel it will just be too rich and slow down I assume?
12 Charger SRT8: LMI Intake, SLP LM exhaust........waiting on CMR, then il buy a Trinity
Re: ACTUAL GAINS!!!
just leaving the track now.... Saw some nice gains. 13.53 at 103 1.98 60 and a 13.52 at 103 1.99 60
those runs were with 91 Oct canned tune throttle boost at 20% shift firmness increased and HS fans on at 170. Also runs were with Frankentake IV CAI.
We let car cool 1 hour before runs with 170 degree coolant temp and it was 69
68 degrees outside with 1400 to 1300 DA.
I never messed with WOT fuel % ... I data logged each run also.
Last hot lap run went 14.08 at 100 2.14 60 .. So hot
lapping makes a big difference!
Best car has gone best stock with K&N drop in 13.66 at 101 in April of this year.
With cooler weather I see 13.40 13.30s
Re: ACTUAL GAINS!!!
coair73x wrote:just leaving the track now.... Saw some nice gains. 13.53 at 103 1.98 60 and a 13.52 at 103 1.99 60
You must an a 5.7L?
eric.hauptman
Re: ACTUAL GAINS!!!
hopefully this colder weather will help a lot i'm seeing some different times as well
Re: ACTUAL GAINS!!!
nice, thats a solid 20 rwhp gaincoair73x wrote:just leaving the track now.... Saw some nice gains. 13.53 at 103 1.98 60 and a 13.52 at 103 1.99 60
Re: ACTUAL GAINS!!!
What do you have ur throttle booster set at?coair73x wrote:just leaving the track now.... Saw some nice gains. 13.53 at 103 1.98 60 and a 13.52 at 103 1.99 60
eric.hauptman
Re: ACTUAL GAINS!!!
20% it's in the second line!coair73x wrote:just leaving the track now.... Saw some nice gains. 13.53 at 103 1.98 60 and a 13.52 at 103 1.99 60
Re: ACTUAL GAINS!!!
Haha that's what I was thinking!mikel wrote:'only' .5-.6 off 0-60 and a full second in the 1/4 mile?
Ethan
First & only 4th gen 4x4 in the 12's NA 12.747 @ 104.07
2012 Black SC 4x4 1500 Hemi, Coated ARH longtubes, Vararam intake,
Circle-D, efan, 2010 frontend swap/4.56 gears, Trinity w Greene Racing tune,
Moe's 87mm throttle body, AEM Wideband
