Ok, I recently bought an inTune to replace my Predator.
All seemed to install and register properly. Also updates seem to go fine. The inTune itself appears to work except it is slow to write log files (if I log for 5 mins it probably takes 3 or 4 mins to write the log).....but the speed is the least of my problems.
Connection stuff and analog logging: This is not good to say the least. I created analog inputs (I did not "reuse" analog1 and 2) to monitor fuel pressure and AFR (for AFR i entered "AFR" for units so its not blank). I cannot see the analog inputs on the inTune screen, I cannot log the analog inputs using the inTune's record feature, I had to struggle to get the analog inputs to show up in DataViewer 3.3 (the latest one). Sometime they show up in DataViewer and sometimes they don't. When they do, I tried to log the AFR but it always showed up as 10 (the minimum) meaning 0 volts - so either the inTune is not seeing the signal or you gave me a bad analog cable. I'm guessing that the analog inputs showing up intermittently is due to the other communications problems I list below. The DataViewer stops reading live data......if i try to disconnect or kill DataViewer, DV can hang or, if it does close it will leave the inTune in "remote" mode. This really needs to be addressed. Between the Predator, inTune, the CMR tunes I have spent a lot of money with you guys. We need to be able to rely on these products...they need to be rock solid. In my opinion....the inTune itself should ensure that the connection is still alive periodically when it is connected to the pc especially in remote control mode. Beef up DataViewer similarly. Sometimes "reacquiring info" helps get the analog back but this is very slow and time consuming. I have disabled all USB power managment. I assume that the DataViewer's serial high speed connection setting affects only serial (predator) type connections and not USB. Please let me know if there are any other settings that need to be tweaked on the pc or inTune to get this working. Also, the analog support needs to addressed.....it was one of the main reasons that I upgraded to the inTune. Please let me know if there are any updates that i need to make....all DS ans WIndows software is up to date. DataViewer is ver. 3.3.0.8. InTune is ver. 1r02d. rpc proto=1.6, protocol=2.0
Also, asumming that this can be resolved and I don't have to return it for a refund, I read that there is a Predator trade in allowance. Please let me know about that. I have had the inTune for less than a month.
intune connectivity issues
Re: intune connectivity issues
we are looking into and investigating these issues, and planning updates to intune and DV to resolve these issues.
