2006 Mustang Gt ProCharged EMMISSIONS
- speedsport
OK, WHATS THE BEST WAY TO GET THE READINESS TESTS TO CLEAR???? GOT LONG TUBES WITH HI FLOWS..EVERYTHING PERFECT BUT IT WONT PASS READINESS TESTS, SO NO TAGS.......MARK
- FBNF1GA.frg
- (960.25 KiB) Downloaded 438 times
Re: 2006 Mustang Gt ProCharged EMMISSIONS
I cant open the file at the moment...what is changed?
Di you have the bit map scalar changed/
ideally you can just set number of rear O2 sensors to 0.
- speedsport
WHEN I GO THROUGH THE DS DL IT DOESNT ASK ABOUT LAST TUNE WRITTEN OR THE 2 PRO CHARGER TUNES THAT ARE IN THERE.....IT ONLY GIVES ME THAT TUNE WHICH I POSTED..
what revision is on the tool?
- speedsport
yeah, thats reallly old....
but it should still let you export it/
If not, try options/custom tune/export tune select custom tune and then get tune file from tool on dsdl....
- speedsport
ok, got everything dialed but still no READINESS...CANT GET THROUGH EMMISSIONS
- danernestpro2.frg
- (960.11 KiB) Downloaded 404 times
ummm...looking at that tune, no way it will pass?
Bit map scalars are changed to disable something (egr, O2s?), o2s are disabled in powertrain config, all that stuff is going to cause problems from what I know.
