hemi 6.1 swap into an RT
Posted: Tue Nov 13, 2012 2:39 pm
Hi all,
So, my 5.7 decided it didn't want to be around and I swapped in a 6.1 into my 2005 magnum. I actually ended up swapping the entire drivetrain back to the axles since I was at it.
I got the Srt8 PCM with the engine and transfer, so that board is in the car at the moment.
The problem we are having is that the abs controller will not initialize with the 6.1 pcm, it throw a configuration mismatch error. The current thought is that if we put the 5.7 pcm back in, it will allow the abs/traction control to initialize.
If I swap the original 5.7 pcm into the car, can I push the 6.1 tunes to the pcm? Would this be considered the same as pushing a custom tune?
Thanks in advance.
Thanks in advance.
