still has ping, need advice
bshort
Post by bshort »
U7153 on 01' f150 screw 4x4 w/ 5.4l. No spark issues and fuel delivery is fine. Still pinging at wot near shift points. Already retarded 10%, less, but still pings. I'm considering keeping the 10% and adding fuel in the 4-7K range. Maybe 1-2 values richer. Any advice? No ping with stock, but can't adjust speedo and gears.
ChrisDiabloSport
Post by ChrisDiabloSport »
Which tune are you running? What octane fuel are you running? If you are running the Performance tune with only 87 octane fuel in the tank this could be what is causing your issue. Try pulling another 10% spark from 4 - 7k and see if this helps get rid of your pinging.
Thank You
Chris Johnson
1865 S.W. 4th Ave. Suite D2
Delray Beach Florida 33444
Phone: 561-908-0040
Fax: 561-908-0048
www.diablosport.com
bshort
Post by bshort »
It is the only tune in the unit, says "diablo tune." I use 91 shell fuel. I already pulled a 10% retard. Do you recommend a total of 20%? Seems a little too much...
joeyz71
Post by joeyz71 »
Hey, this sounds like what I just went through. Have someone do a back pressure test on your cats. Mine were plugging up, so they were hollowed out and now she goes like a raped ape (yes- that's the technical term). Check your knock sensors too. This may be of help or a waste of time, so good luck.
ChrisDiabloSport
The Performance Tunes in the Predator are made for 93 Octane, so pulling the 10% out would help, maybe you could try removing another 5% and see how it does? Do you have any other modifications done to your truck, like a CAI etc... If you think you might be running on the lean side you can check your Long Term Fuel trims under using the Real Time Data section under Diagnostics. As long as they are in the +/- 8% range at idle and cruise you should be fine.
Thank You
Chris Johnson
Phone: 561-908-0040
Fax: 561-908-0048
www.diablosport.com
Return to “Predator Ford Gas”
