2010 ram hemi idle issue
Posted: Thu Jan 17, 2013 4:23 pm
by adventurer
Hi all, am facing a problem when i raise the idle on my 2010 ram , normal on drive its 500 rpm so i tried to raise it to 700 rpm by adding 200 rpm using the predator with nothing happens it stays 500 on drive so i tried to raise 50 rpm to all : on N and Park with AC on and on D with AC on and also with AC off , it raised to 1200 rpm and wont go down , and when i raise only on D with AC off nothing happens it stayed 500 rpm no matter how many rpms i raise , any help how to raise it to at least 600 or 700 ??
Re: 2010 ram hemi idle issue
Posted: Wed Jan 23, 2013 4:55 pm
by adventurer
till now 6 days passed on post and no one can help !!
Posted: Wed Jan 23, 2013 5:37 pm
so, you can raise it to 1200, but not 700, am I reading that correctly?
Posted: Wed Jan 23, 2013 5:48 pm
by adventurer
mikel wrote:so, you can raise it to 1200, but not 700, am I reading that correctly?
if i add 50 rpm to each N and P when ac on and to D when ac on and the same when ac off it raises to 1200 rpm in all conditions and if i only add to when on D with ac off alone nothing happens
Posted: Wed Jan 23, 2013 7:08 pm
please make the changes you mentioned, load the tune to the truck, then grab a copy of the last tune written from the Predator using DSDL and post it here.
What revision is the tool on?
Posted: Wed Jan 23, 2013 7:12 pm
by adventurer
am using on tool 9r13
