WOT 74%
Posted: Thu Jan 24, 2013 6:19 pm
by burnrubber
Is it normal for data viewer to show 74% throttle at WOT ? 2012 V6 Mustang .Thanks in advance
Re: WOT 74%
Posted: Thu Jan 24, 2013 6:49 pm
got a log you can post?
Re: WOT 74%
Posted: Thu Jan 24, 2013 8:27 pm
by burnrubber
New to this have logs dont know how to post them.
Re: WOT 74%
Posted: Sat Jan 26, 2013 11:57 am
by 5liter Monsta
Normal. Relative throttle position for my GT show the same. My camaro did the same.
Re: WOT 74%
Posted: Sat Jan 26, 2013 1:35 pm
by 157dB
Try re-calibrating your throttle pedal.
Turn key to run position.
Do not start engine.
Fully depress and release the throttle pedal SLOWLY
3 times within 5 seconds.
Turn key off.
Pedal calibrated.
This did wonders for my 07 Mustang.
Re: WOT 74%
Posted: Sat Jan 26, 2013 4:16 pm
by 5liter Monsta
157dB wrote:Try re-calibrating your throttle pedal.
Turn key off.
Pedal calibrated.
but this doesnt change the fact that the rel throttle position will still read below 100% correct?
Re: WOT 74%
Posted: Mon Jan 28, 2013 5:29 pm
by burnrubber
I will give it a try thanks.
Re: WOT 74%
Posted: Mon Jan 28, 2013 6:06 pm
by sohfast94
5liter Monsta wrote:157dB wrote:Try re-calibrating your throttle pedal.
Turn key off.
Pedal calibrated.
05-10 Fords only read up to 82% The 11-ups 90%
As far as the 74% do you have a log of it doing this?
The cars we've had in here didn't exhibit this although if it were to be doing it I'm sure I could fix it easily.
Re: WOT 74%
Posted: Tue Jan 29, 2013 8:13 am
by burnrubber
It is 74.90% the question is, is the throttle only opening 74.90% or is the logging software just off abit.
Re: WOT 74%
Posted: Tue Jan 29, 2013 12:07 pm
software is reporting whatever the PCM tells it
