U7135 menu map
U7135 menu map
This was created by one of our users. It may be helpfull to anyone using the Hemi Predator.
It is a complete map of the Predators menus, with some nice help features as well.
Enjoy.
http://www.xeryder.com/predator/Predato ... enuMap.xls
AZOTH99
RE: U7135 menu map
Post by AZOTH99 »
link is not working when I try to open it.
07 CHARGER R/T: 6.1L Cam, springs, & rods, Dynatech headers W/ Hi-Flow Cats, AFE CAI, Catch Can, Flowmaster Catback, Jet 180 T-Stat, Hotchkis Sways. All installed by myself, I paid no one for installation of any mods.
Future mod wishlist: Pedders suspension, heads, bigger cam, LC-1, & Nitrous.
johnc
RE: U7135 menu map
Post by johnc »
Here is a PDF printout of that map if you do not have MS Excel.
Right click, select "Save Link As..." or "Save File As...".
If you do not have a PDF viewer, you can get Sumatra PDF.
johnc <at> diablosport.com
XERyder
Menu Maps
Post by XERyder »
Glad you are finding this helpful!
There are two Menu Map sheets, and the spreadsheets are in MS Excel format. Microsoft offers a free Excel spreadsheet viewer here:
http://www.microsoft.com/downloads/deta ... laylang=EN
The first sheet covers all the menu options up to entering the Live Data logging section, then the second has nearly all the PIDs of loggable sensors.
NOTE: There may be some difference in available PID's by model year. If I can get hold of various model years, I will fill in any differences.
UARPerformance
RE: Menu Maps
Post by UARPerformance »
Hey thanks for microsoft download info XERyder.
UAR Performance.com
HemiHorsePower
EGR?
Post by HemiHorsePower »
Hello. when I installed the Dynatech Header system for 06 Ram Hemi 1500, I've been pulling codes with the check engine light on and with the codes I'm getting it seems as if all 4 sensors are affected, rather then just the rear ones. What's the difference between turning off the rear 02 sensors, and turning off the EGR in the predator? Does doing this affect the performance?
I'm trying to see if the tool will help me correct the problem , I've tried the sparkplug non-fowlers too, but they did not work, instead they threw more codes.
any advise would be appreciated
thanks
HH
UARPerformance
RE: EGR?
[quote="HemiHorsePower"]Hello. when I installed the Dynatech Header system for 06 Ram Hemi 1500, IWhat were the codes exactly? Why are you turning off EGR. Headers not EGR compatible? Do the codes come right back on, or do you have to drive for upstream codes. You will probably need a real scanner or programmer to find the codes exact description. Ck engine light is generic form of code extraction.
RDay1
downloading predator files on a Mac
Post by RDay1 »
U7135
U7135-9r08
2008 Dodge Challenger
Can you download the update revision on a Mac.?
R Day
mrem1080
Post by mrem1080 »
Good question RDay I'd like to know also.
Nope. The DS Downloader software is for PC only.
johnc
Post by johnc »
Some users have gotten DSDL to work on their macs using Parallels and Bootcamp: here
Cruisin1966
Post by Cruisin1966 »
Or VMWare Fusion and Windows XP. ;)
2007 Sublime Daytona #082/150
McKinney catch can (to be installed)
XERyder
Still Around - MenuMap Link Update
Post by XERyder »
Hello Folks!
Yes, I'm still out here but been very busy!
Here is an updated link to the menumap xls: http://www.case-enterprises.com/xeryder ... enuMap.xls
And of course the handy PDF version: http://www.diablosport.com/beta/Predato ... enuMap.pdf
Now Go Raise Hell!
XE
chrisl626
RE: Still Around - MenuMap Link Update
Post by chrisl626 »
Is this menu map basically the same for v.9r18?
300cdreams
Re: RE: Still Around - MenuMap Link Update
Post by 300cdreams »
chrisl626 wrote:Is this menu map basically the same for v.9r18?
What is mode 1 and mode 2 is the autostick menu it made my transmission shut off electronically with an error after hitting 6000rpm
