Page 1 of 2
U7135 menu map
Posted: Wed Nov 14, 2007 12:02 pm
This was created by one of our users. It may be helpfull to anyone using the Hemi Predator.
It is a complete map of the Predators menus, with some nice help features as well.
Enjoy.
http://www.xeryder.com/predator/Predato ... enuMap.xls
RE: U7135 menu map
Posted: Thu Nov 15, 2007 9:53 am
by AZOTH99
link is not working when I try to open it.
RE: U7135 menu map
Posted: Thu Nov 15, 2007 11:32 am
by johnc
Here is a PDF printout of that map if you do not have MS Excel.
Right click, select "Save Link As..." or "Save File As...".
If you do not have a PDF viewer, you can get Sumatra PDF.
Menu Maps
Posted: Fri Nov 16, 2007 12:22 pm
by XERyder
Glad you are finding this helpful!
There are two Menu Map sheets, and the spreadsheets are in MS Excel format. Microsoft offers a free Excel spreadsheet viewer here:
http://www.microsoft.com/downloads/deta ... laylang=EN
The first sheet covers all the menu options up to entering the Live Data logging section, then the second has nearly all the PIDs of loggable sensors.
NOTE: There may be some difference in available PID's by model year. If I can get hold of various model years, I will fill in any differences.
RE: Menu Maps
Posted: Sat Nov 17, 2007 9:48 am
by UARPerformance
Hey thanks for microsoft download info XERyder.
EGR?
Posted: Fri Dec 14, 2007 7:51 pm
by HemiHorsePower
Hello. when I installed the Dynatech Header system for 06 Ram Hemi 1500, I've been pulling codes with the check engine light on and with the codes I'm getting it seems as if all 4 sensors are affected, rather then just the rear ones. What's the difference between turning off the rear 02 sensors, and turning off the EGR in the predator? Does doing this affect the performance?
I'm trying to see if the tool will help me correct the problem , I've tried the sparkplug non-fowlers too, but they did not work, instead they threw more codes.
any advise would be appreciated
thanks
HH
RE: EGR?
Posted: Sun Dec 16, 2007 1:34 pm
by UARPerformance
[quote="HemiHorsePower"]Hello. when I installed the Dynatech Header system for 06 Ram Hemi 1500, IWhat were the codes exactly? Why are you turning off EGR. Headers not EGR compatible? Do the codes come right back on, or do you have to drive for upstream codes. You will probably need a real scanner or programmer to find the codes exact description. Ck engine light is generic form of code extraction.
downloading predator files on a Mac
Posted: Wed Aug 27, 2008 7:49 pm
by RDay1
U7135
U7135-9r08
2008 Dodge Challenger
Can you download the update revision on a Mac.?
R Day
Posted: Mon Oct 27, 2008 1:59 am
by mrem1080
Good question RDay I'd like to know also.
Posted: Mon Oct 27, 2008 9:24 am
by Mike_Levy
Nope. The DS Downloader software is for PC only.
Posted: Mon Oct 27, 2008 11:57 am
by johnc
Some users have gotten DSDL to work on their macs using Parallels and Bootcamp: here
Posted: Fri Jul 24, 2009 7:06 pm
by Cruisin1966
Or VMWare Fusion and Windows XP. ;)
Still Around - MenuMap Link Update
Posted: Sat Aug 29, 2009 12:56 pm
by XERyder
Hello Folks!
Yes, I'm still out here but been very busy!
Here is an updated link to the menumap xls: http://www.case-enterprises.com/xeryder ... enuMap.xls
And of course the handy PDF version: http://www.diablosport.com/beta/Predato ... enuMap.pdf
Now Go Raise Hell!
XE
RE: Still Around - MenuMap Link Update
Posted: Tue Sep 22, 2009 3:51 am
by chrisl626
Is this menu map basically the same for v.9r18?
Re: RE: Still Around - MenuMap Link Update
Posted: Wed Sep 23, 2009 9:15 pm
by 300cdreams
chrisl626 wrote:Is this menu map basically the same for v.9r18?
What is mode 1 and mode 2 is the autostick menu it made my transmission shut off electronically with an error after hitting 6000rpm
