Page 1 of 2
InTune will no longer turn off DOD
Posted: Sat Feb 02, 2013 6:31 pm
by TJEli
Something weird is going on with the GM DOD settings. I have an 08 Silverado with the L76 6.0L. My InTune worked perfect 2 weeks ago and turned off DOD first try. I had to send it in for repair so I removed my tune. When I got it back yesterday I plugged it in to get current updates. Guess what? Now it will not turn off DOD. I tried it in my 87 octane tune, went back in to parameters and it said "off" but it was still active. I set it to "on" and road tested (it was on like it should have been). I then set it back to "off" and road tested and it was still on. (going into V4 mode). Checked parameters again and it was listed as "off". What changed in the last 2 weeks? It was working perfect.
-Eli
Re: InTune will no longer turn off DOD
Posted: Sun Feb 03, 2013 1:31 pm
yep, known issue with the latest update that was put out... they're aware of it and are working on a fix/new update....
Posted: Sun Feb 03, 2013 4:55 pm
by kdodd
TJEli wrote:Something weird is going on with the GM DOD settings. I have an 08 Silverado with the L76 6.0L. My InTune worked perfect 2 weeks ago and turned off DOD first try. I had to send it in for repair so I removed my tune. When I got it back yesterday I plugged it in to get current updates. Guess what? Now it will not turn off DOD. I tried it in my 87 octane tune, went back in to parameters and it said "off" but it was still active. I set it to "on" and road tested (it was on like it should have been). I then set it back to "off" and road tested and it was still on. (going into V4 mode). Checked parameters again and it was listed as "off". What changed in the last 2 weeks? It was working perfect.
-Eli
I am having the same issue with my 07 6.0L if you here some news on that fix hit me up.
Posted: Sun Feb 03, 2013 9:30 pm
by TJEli
06MonteSS wrote:yep, known issue with the latest update that was put out... they're aware of it and are working on a fix/new update....
Is there any way I can revert back one update? Any eta on the fix?
-Eli
Posted: Mon Feb 04, 2013 11:57 am
post backup and LTW if you need a custom tune for now please.
Posted: Mon Feb 04, 2013 12:01 pm
by TJEli
Here you go... Should be 87 octane tune with DOD disabled.
-Eli
Posted: Mon Feb 04, 2013 12:16 pm
TJEli wrote:Here you go... Should be 87 octane tune with DOD disabled.
-Eli
here you go.
Posted: Mon Feb 04, 2013 12:41 pm
by TJEli
Thanks Mike. I will load this and give it a shot. Any idea when the repaired update will be available?
Thanks for the help,
-Eli
Posted: Tue Feb 05, 2013 5:11 pm
by TJEli
Mike,
Just wanted to let you know that your custom file removed AFM. Thanks for that. Can you let us know when the fixed update is out? I would like to do some more tuning but I need AFM to remain off.
-Eli
Posted: Tue Feb 05, 2013 5:47 pm
if you want to modify the tune, you can.. and AFM will stay off... select the custom tune to install, then select modify tune, make your adjustments, save the changes, install tune... piece a cake...
it will reinstall the custom tune with the AFM off and whatever changes you made...
Posted: Wed Feb 06, 2013 10:51 am
by tbenzie
Mike - can you do the same for me? (disable DOD)
Posted: Wed Feb 06, 2013 11:40 am
tbenzie wrote:Mike - can you do the same for me? (disable DOD)
here you go.
Posted: Wed Feb 06, 2013 2:27 pm
by tbenzie
Posted: Sat Apr 13, 2013 7:39 pm
by dguth66
Hey guys
I get my Trinity next week, is this still a problem with my 10 Silverado w/5.3 ?
Posted: Sat Apr 13, 2013 8:16 pm
this was never a problem for the Trinity... it was an intune issue, hence why this is in the intune forum/thread ;)
