InTune will no longer turn off DOD
Something weird is going on with the GM DOD settings. I have an 08 Silverado with the L76 6.0L. My InTune worked perfect 2 weeks ago and turned off DOD first try. I had to send it in for repair so I removed my tune. When I got it back yesterday I plugged it in to get current updates. Guess what? Now it will not turn off DOD. I tried it in my 87 octane tune, went back in to parameters and it said "off" but it was still active. I set it to "on" and road tested (it was on like it should have been). I then set it back to "off" and road tested and it was still on. (going into V4 mode). Checked parameters again and it was listed as "off". What changed in the last 2 weeks? It was working perfect.
-Eli
-Eli
Re: InTune will no longer turn off DOD
yep, known issue with the latest update that was put out... they're aware of it and are working on a fix/new update....
I am having the same issue with my 07 6.0L if you here some news on that fix hit me up.TJEli wrote:Something weird is going on with the GM DOD settings. I have an 08 Silverado with the L76 6.0L. My InTune worked perfect 2 weeks ago and turned off DOD first try. I had to send it in for repair so I removed my tune. When I got it back yesterday I plugged it in to get current updates. Guess what? Now it will not turn off DOD. I tried it in my 87 octane tune, went back in to parameters and it said "off" but it was still active. I set it to "on" and road tested (it was on like it should have been). I then set it back to "off" and road tested and it was still on. (going into V4 mode). Checked parameters again and it was listed as "off". What changed in the last 2 weeks? It was working perfect.
-Eli
Is there any way I can revert back one update? Any eta on the fix?06MonteSS wrote:yep, known issue with the latest update that was put out... they're aware of it and are working on a fix/new update....
-Eli
post backup and LTW if you need a custom tune for now please.
Here you go... Should be 87 octane tune with DOD disabled.
-Eli
-Eli
- ECM_12653934_Backup.grg
- (59.51 KiB) Downloaded 324 times
- ECM_12653934_LastTuneWritten.grg
- (59.27 KiB) Downloaded 254 times
here you go.TJEli wrote:Here you go... Should be 87 octane tune with DOD disabled.
-Eli
- ecm_12653934_dod_off.grg
- (55.19 KiB) Downloaded 393 times
Thanks Mike. I will load this and give it a shot. Any idea when the repaired update will be available?
Thanks for the help,
-Eli
-Eli
Mike,
Just wanted to let you know that your custom file removed AFM. Thanks for that. Can you let us know when the fixed update is out? I would like to do some more tuning but I need AFM to remain off.
Thanks,
-Eli
Thanks,
-Eli
if you want to modify the tune, you can.. and AFM will stay off... select the custom tune to install, then select modify tune, make your adjustments, save the changes, install tune... piece a cake...
it will reinstall the custom tune with the AFM off and whatever changes you made...
Mike - can you do the same for me? (disable DOD)
- ECM_12614093_LastTuneWritten.grg
- (50.86 KiB) Downloaded 273 times
- ECM_12614093_Backup.grg
- (51.07 KiB) Downloaded 298 times
here you go.tbenzie wrote:Mike - can you do the same for me? (disable DOD)
- ecm_12614093_no_dod.grg
- (47.16 KiB) Downloaded 390 times
Hey guys
I get my Trinity next week, is this still a problem with my 10 Silverado w/5.3 ?
If you're not having fun......you are doing it wrong. :-)
this was never a problem for the Trinity... it was an intune issue, hence why this is in the intune forum/thread
