InTune will no longer turn off DOD
TJEli
Post by TJEli »
Something weird is going on with the GM DOD settings. I have an 08 Silverado with the L76 6.0L. My InTune worked perfect 2 weeks ago and turned off DOD first try. I had to send it in for repair so I removed my tune. When I got it back yesterday I plugged it in to get current updates. Guess what? Now it will not turn off DOD. I tried it in my 87 octane tune, went back in to parameters and it said "off" but it was still active. I set it to "on" and road tested (it was on like it should have been). I then set it back to "off" and road tested and it was still on. (going into V4 mode). Checked parameters again and it was listed as "off". What changed in the last 2 weeks? It was working perfect.
-Eli
Re: InTune will no longer turn off DOD
yep, known issue with the latest update that was put out... they're aware of it and are working on a fix/new update....
kdodd
Post by kdodd »
TJEli wrote:Something weird is going on with the GM DOD settings. I have an 08 Silverado with the L76 6.0L. My InTune worked perfect 2 weeks ago and turned off DOD first try. I had to send it in for repair so I removed my tune. When I got it back yesterday I plugged it in to get current updates. Guess what? Now it will not turn off DOD. I tried it in my 87 octane tune, went back in to parameters and it said "off" but it was still active. I set it to "on" and road tested (it was on like it should have been). I then set it back to "off" and road tested and it was still on. (going into V4 mode). Checked parameters again and it was listed as "off". What changed in the last 2 weeks? It was working perfect.
-Eli
I am having the same issue with my 07 6.0L if you here some news on that fix hit me up.
TJEli
Post by TJEli »
06MonteSS wrote:yep, known issue with the latest update that was put out... they're aware of it and are working on a fix/new update....
Is there any way I can revert back one update? Any eta on the fix?
-Eli
post backup and LTW if you need a custom tune for now please.
TJEli
Post by TJEli »
Here you go... Should be 87 octane tune with DOD disabled.
-Eli
ECM_12653934_Backup.grg
(59.51 KiB) Downloaded 326 times
ECM_12653934_LastTuneWritten.grg
(59.27 KiB) Downloaded 257 times
TJEli wrote:Here you go... Should be 87 octane tune with DOD disabled.
-Eli
here you go.
ecm_12653934_dod_off.grg
(55.19 KiB) Downloaded 393 times
TJEli
Post by TJEli »
Thanks Mike. I will load this and give it a shot. Any idea when the repaired update will be available?
Thanks for the help,
-Eli
TJEli
Post by TJEli »
Mike,
Just wanted to let you know that your custom file removed AFM. Thanks for that. Can you let us know when the fixed update is out? I would like to do some more tuning but I need AFM to remain off.
-Eli
if you want to modify the tune, you can.. and AFM will stay off... select the custom tune to install, then select modify tune, make your adjustments, save the changes, install tune... piece a cake...
it will reinstall the custom tune with the AFM off and whatever changes you made...
tbenzie
Post by tbenzie »
Mike - can you do the same for me? (disable DOD)
ECM_12614093_LastTuneWritten.grg
(50.86 KiB) Downloaded 274 times
ECM_12614093_Backup.grg
(51.07 KiB) Downloaded 298 times
tbenzie wrote:Mike - can you do the same for me? (disable DOD)
here you go.
ecm_12614093_no_dod.grg
(47.16 KiB) Downloaded 390 times
tbenzie
Post by tbenzie »
dguth66
Post by dguth66 »
Hey guys
I get my Trinity next week, is this still a problem with my 10 Silverado w/5.3 ?
If you're not having fun......you are doing it wrong. :-)
this was never a problem for the Trinity... it was an intune issue, hence why this is in the intune forum/thread ;)
