08 6.4 f250 flash wont work
big_boost
Post by big_boost »
just bought a predator u7164 for my f250 2008 6.4 diesel , and when i try to flash it says that it's not supported for this vehicule . the only thing that it showed was : unit 1 8u7a-14c204-ck unit 2 7u7a-14c337-ab.
what should i do to make i work with my truck .....
tks :D
Re: 08 6.4 f250 flash wont work
whats the revision on the top line of the main menu, and when was the last time this truck was at the dealership?
big_boost
Post by big_boost »
the truck was at the dealership about three days ago... i have to plug my predator to see that ??
to see the version, yes.
it likely needs to be updated to the latest.
big_boost
Post by big_boost »
the only thing is , there is no wire in the box so that i can plug it in the predator tru the computer....
you need a USB to serial cable to connect it to a PC
big_boost
Post by big_boost »
i've done the update 9r16 and it still says that the vehicule is not supported ?? what could it be ??
it seems you have not been updated by ford to the latest cals, id let them update it or we'll need to backdate the tool to make it work.
big_boost wrote:i've done the update 9r16 and it still says that the vehicule is not supported ?? what could it be ??
try this one
u7164-9t17a.crom
(4 MiB) Downloaded 621 times
big_boost
Post by big_boost »
the tune u send me work like a charm , expect that my truck as a pdf delete and it keeps going into safety mode even if thers no check engine lights on .... does the tune support the pdf delete ??
big_boost
Post by big_boost »
here are the code list :p1335 / p0404 / p2452 / p1000
no, we do not support dpf delete.
