08 6.4 f250 flash wont work
Posted: Fri Mar 08, 2013 9:27 am
by big_boost
just bought a predator u7164 for my f250 2008 6.4 diesel , and when i try to flash it says that it's not supported for this vehicule . the only thing that it showed was : unit 1 8u7a-14c204-ck unit 2 7u7a-14c337-ab.
what should i do to make i work with my truck .....
tks :D
Re: 08 6.4 f250 flash wont work
Posted: Fri Mar 08, 2013 10:43 am
whats the revision on the top line of the main menu, and when was the last time this truck was at the dealership?
Posted: Fri Mar 08, 2013 2:23 pm
by big_boost
the truck was at the dealership about three days ago... i have to plug my predator to see that ??
Posted: Fri Mar 08, 2013 2:25 pm
to see the version, yes.
it likely needs to be updated to the latest.
Posted: Sat Mar 09, 2013 1:53 pm
by big_boost
the only thing is , there is no wire in the box so that i can plug it in the predator tru the computer....
Posted: Tue Mar 12, 2013 4:11 pm
you need a USB to serial cable to connect it to a PC
Posted: Tue Mar 19, 2013 9:23 am
by big_boost
i've done the update 9r16 and it still says that the vehicule is not supported ?? what could it be ??
Posted: Tue Mar 19, 2013 12:19 pm
it seems you have not been updated by ford to the latest cals, id let them update it or we'll need to backdate the tool to make it work.
Posted: Tue Mar 19, 2013 12:22 pm
big_boost wrote:i've done the update 9r16 and it still says that the vehicule is not supported ?? what could it be ??
try this one
Posted: Wed Mar 20, 2013 1:51 pm
by big_boost
the tune u send me work like a charm , expect that my truck as a pdf delete and it keeps going into safety mode even if thers no check engine lights on .... does the tune support the pdf delete ??
Posted: Wed Mar 20, 2013 2:47 pm
by big_boost
here are the code list :p1335 / p0404 / p2452 / p1000
Posted: Wed Mar 20, 2013 6:20 pm
no, we do not support dpf delete.
