P0133 code
RamMan86
P0133 code
Post by RamMan86 »
All 4 o2 sensors were replaced 3 months ago as well as the wiring. I had a CMR tune because of the long tube headers. Previous to the tune I was getting this code once a week. Since I got the tune done 2 months I haven't seen the code until today. Ive had a brand new exhaust system put on and headers resealed just to make sure there were no leaks. Any advice on what to do next?
2007 Dodge Ram 5.7 Hemi, Trinity CMR tune, K&N FIPK, 87mm ported TB, Dynatech Supermaxx LT headers, Magnaflow cats & ypipe, Magnaflow muffler, Jetstream Scoop, DIY Ram Air, 2" level kit, blacked out brake lights, all chrome blacked out
Re: P0133 code
O2 extension harnesses installed?
RamMan86
Re: P0133 code
Post by RamMan86 »
I believe the dealership had to splice one together
Re: P0133 code
thats the issue :)
RamMan86
Re: P0133 code
Post by RamMan86 »
Ok great! Im glad its now pinpointed. Im sure its a dumb question at this point but what should I do to fix this?
Re: P0133 code
try replacing the harness with a proper one (not made in china or spliced together with cheap wire).
RamMan86
Re: P0133 code
Post by RamMan86 »
Do they make wires long enough to accommodate for the long tube headers? If so any recommendations on where I can get those?
BdyGrd
Re: P0133 code
Post by BdyGrd »
2012 R/T Max - DS Trinity 93 Oct tune; LMI Frankentake IV; Mid-Muffler delete; BT Catch Can; 30% tint fronts, 20% back and rear; Escort Passport 9500 ix; TX Toll Tag <--- LOL! ;-P
RamMan86
Re: P0133 code
Post by RamMan86 »
Before I order a set of extensions to get rid of the spliced wires, I wanted to see if I could get something clarified. I was under the impression that its usually the rear o2 wires that need to be extended. And my code is for sensor 1 bank 1. So Im not exactly sure which one was spliced. Also I was told by my CMR tuner that he did not tune out that code, he just changed the timing to account for the extra distance. He told me I could bring it in but it sounds like hes going to charge me for something I had already paid to have done.
Re: P0133 code
Depends on the headers. Some extend the fronts too.
If you do decide to get new extensions, Caspers Electronics is the only way to go IMO. I used their extensions on my Jeep and the problem was solved instantly.
RamMan86
Re: P0133 code
Post by RamMan86 »
I got a chance to take a look under the truck today and the front o2 sensors were not the ones that needed the extensions. So now I am not sure what to do next. If the sensors are only 2 months old I just don't think I should bother replacing it. Any advice is definitely appreciated.
Re: P0133 code
burnt harness/wiring on the headers?
RamMan86
Re: P0133 code
Post by RamMan86 »
The wire and harness both look perfect. On the other hand the passenger side looks a little ghetto, wrapped in electrical tape. But the code keeps reading p0133 slow o2 response sensor 1 bank 1. Which correct me if Im wrong but that is pre cat drivers side? I will go ahead and try replacing the passenger side. But just confused with it all.
RamMan86
Re: P0133 code
Post by RamMan86 »
After taking my throttle body off I realized there is no gasket between the throttle body and the throttle body spacer. So if it is metal on metal with no gasket I see the great possibility in creating a leak. Could a leak at this location cause that p0133 code?
Re: P0133 code
Not likely...
