Anyone have a "stability sys disabled" error on GM.
Posted: Thu Apr 18, 2013 4:49 pm
by danzigman
I get this error after I try to adjust the tire size on my '05 Tahoe Z71 2x4 87 Octane Tune. The tune works fine until I adjust the tire size. I am trying to adjust it to 275/55/r20 which is the factory wheel and tire combo on a '05 Silverado SS. It is also a standard size on later model Tahoes. It would seem to me that this should be a no brainer tweek to the standard tunes.
Re: Anyone have a "stability sys disabled" error on GM.
Posted: Mon Apr 22, 2013 9:17 pm
by Oldsaltydog
I had to put the actual tire height measured with a tape measure in to get it correct finally got it right by playing with that number up and down.
Posted: Mon Apr 22, 2013 10:14 pm
by 06MonteSS
yes correct ^ ^ ^
do not go by the numbers on the tire sidewall... you need to actually measure your tire from the ground to the top of the tire for best/correct results...
Posted: Tue Apr 23, 2013 10:51 am
by danzigman
Thanks, I will give the a try. Can I use the width on the tire of try to measure that as well?
Posted: Tue Apr 23, 2013 5:18 pm
by Oldsaltydog
No width input only tire height measured with a tape measure the go from there
