Gear Ratio?
Posted: Tue May 14, 2013 9:28 pm
by Garza
What's the difference between the three gear ratios you have in the tune setup? Is it better to use a higher ratio?
Re: Gear Ratio?
Posted: Wed May 15, 2013 9:57 am
only adjust this if you changed the gears in your rear end.
Re: Gear Ratio?
Posted: Sat Oct 19, 2013 12:49 pm
by indypace78
If I change my rear gears from 3.06 to 3.92 do I need to change anything else in the programmer or will shift points be changed automatically?
Re: Gear Ratio?
Posted: Mon Oct 21, 2013 9:56 am
Just the axle ratio setting is all thats needed.
