Is there a way to delete CAGS from the program on my 2002 M6 Corvette?
I have a module hooked to the harness but the CAGS dash light comes on occasionally and I would like to turn that off as well.
I looked at the intune menu closely but all the variable parameters are for an A4
automatic.
Deleting CAGS 2002 Corvette
Re: Deleting CAGS 2002 Corvette
have you tried disconnecting that harness??? you don't need that thing at all for disabling cags with the tool... that may be causing your issue... since that module is disabling the cags, the tool may be seeing the tranny as being an auto instead of a manual? not sure...
so disconnect that aftermarket module/harness, then connect the tool and try again...
I'm having this same issue - I see no value / field for CAGS in the i3 under. i'd like to delete VATS too
CAGS should be disabled in the tune. LMK if not.Robvette wrote: Wed Nov 22, 2023 11:11 pm I'm having this same issue - I see no value / field for CAGS in the i3 under. i'd like to delete VATS too
