Page 1 of 2
F150 shift firmness, am I missing something
Posted: Wed Oct 30, 2013 2:07 pm
by cozmo1311
In the description for the Diablo Predator it states shift firmness as a parameter. My U7151 does not include this option, I have updated it to the newest firmware. I just wanted some firmer shifts, one of the many reasons I purchased the tuner.
Re: F150 shift firmness, am I missing something
Posted: Wed Oct 30, 2013 4:43 pm
by Vas@Diablosport
If you do not have that option, Try posting your original backup and last tune written here and I'll see if the firmness can be increased in a custom tune for you.
Posted: Wed Oct 30, 2013 9:27 pm
by cozmo1311
Awesome thanks. I want them firmed up pretty good for moderate throttle, the aggressive throttle shifting can be firmed up just a little. Also can anything be done about the torque converter on my truck being all plushy. Like when its not locked in overdrive, I can press the throttle and the car will gain rpms then begin to accelerate.
Thank you for the quick response.
Posted: Thu Oct 31, 2013 12:30 pm
by sohfast94
This doesn't seem to be your last tune written. Which tune did you load?
Posted: Thu Oct 31, 2013 4:55 pm
by cozmo1311
87 octane , stock performance tune. No adjustments
Posted: Thu Oct 31, 2013 4:57 pm
can you reload it, then grab a new copy of the last tune written please?
Posted: Fri Nov 01, 2013 1:32 pm
by cozmo1311
Alright reloaded it.
Posted: Fri Nov 01, 2013 2:39 pm
by sohfast94
before I play with any of the pressures please try this and tell me if this is enough or more and where.
Posted: Mon Nov 04, 2013 1:05 pm
by cozmo1311
After two days of testing, everything is fine with the tune. No check engine lights or strange happenings. If the shifting could be three times as much as it is set to now that would great or atleast a good starting point. Really looking for firm shifts at light-moderate throttle.
Thank you
Posted: Mon Nov 04, 2013 5:52 pm
by sohfast94
3x more firm? If so, I can do that
Posted: Tue Nov 05, 2013 1:47 am
by cozmo1311
Not Sure if you were clarifying my request, but yes 3x more shift pressure. If the last tune you made already incorporated this change than, after testing I have discovered I would like 2x as much as already applied and see how that works out. Also if adding more line pressure to the torque converter is possible that would be great. When my truck does shift the rpm never actually changes because the torque converter I guess is trying to use torque management.
Thank You Brian
Posted: Tue Nov 05, 2013 9:53 am
by sohfast94
Did you load R3?
Posted: Tue Nov 05, 2013 8:01 pm
by cozmo1311
Yea of course. I could feel the shifts but barely.
Posted: Thu Nov 07, 2013 12:26 pm
by sohfast94
R4
Posted: Thu Nov 14, 2013 7:50 pm
by cozmo1311
Brian I am satisfied with the tunes. Thank you for your consideration and help. Someone at Diablosport, I recommend Brian for a raise or bonus this holiday.
Thank you to all the Diablosport staff
