no audio controls now...
all was well, loaded with MPG tune.
took to dealer so put it back to stock.
after dealer, reloaded mpg tune and throttle booster, now my audio controls don't work, and my N/S/E/W compass isnt displayed or any where to be found on my instrument cluster. also, all tire pressures show 0psi. and upon start up it shows check TPM system.
so i figured somethin may be screwy with the tune. threw it back to stock. same issue. cannot control radio functions with steering wheel controls. cruise works, all that stuff. just no audio controls, no compass and that TPM system check.
what's the deal?
what's the deal?
2013 Wrangler JKU - Auto
Re: no audio controls now...
just linked it up to my computer and it's updating right now. can i still pull it off after the update?
well, since its updating, try writing a tune and see if the issue is resolved, then post the info file if it doesnt.
ok. just finished it's update. it's showing dcx gas v1r10b. i guess this is the latest. i'll try to load a tune again and see what happens.
so i got the tpms to work, had it disabled i guess. so that's all good. but still no audio controls or compass.
not sure if this is what you want or not but:
serial: 6JXXW61-1
Part: dcx_gas
Version: v.1r10b
Bootlader Version: 25.117
Bus: CAN SCIA SCIB VPW
CAL ID 68149821AC
is there something other than that that you need?
Thx.
serial: 6JXXW61-1
Part: dcx_gas
Version: v.1r10b
CAL ID 68149821AC
Thx.
that's the tune from off the trinity. the one that's loaded into the Jeep now.
unmarry and plug back into the DS Downloader and let it update again. 1r10c is what's most recent.
ok. not sure why it didnt update to that earlier today. it had 5 updates to install. installed all 5. k...i'll give it a shot. not sure why the update would have anything to do with it since it was working fine before on the previous version.
ok. 1r10c is uploaded now. gonna do this tune dance again. i'm just confused as to why if it's "returned to stock" that my compass is lost and my audio controls are lost.
hope this works.
hope this works.
even when back to stock they're not showing up? try a battery disconnect for 10-15 min and report back
Same here 2013 jeep jk auto,
TPMS show 0 and audio controls not working after 10 days using trinity! i tried to restore and battry disconnect but problem not go then go to dealer for fix.
the biggest problem when i disable traction control and drive in 4L with manual mod when i lock in 3rd gear for uphill it stack in 3ed gear and never change and show check engin!! and i have to turn the engin off then after 5min it will do the same!! befor i buy the trinity i used to pull fuse 40 to disable the traction and no bad thing happen to me but with trinity not good at all.
do somthing please
do somthing please
yeah, no luck still.
tune was all good till i went back to factory tune before i took it to the dealer this morning. ever since then i havent been able to get the compass and audio back. updated, stock, tuned, whatever. even after the battery disconnect for 20 min. no change.
