New to Data Logging but not computers...
Was able to do a quick data log using the InTune DCX. Above is a screen shot from a select time in the Data Log.
My question regards understanding the KNK ST Retard trace - is what I am seeing with the trace an indication of spark knock. If so, I assume this will have an effect on the overall spark advance?
For what it's worth, I likely am running 89 octain gas (just don't remember what went into the tank last) and currently using the 91 octain DS tune.
Any feedback would be appreciated.
Edit: little hard to read values in pic.
Throttle Blade Position = 76.22 (interesting, was at WOT)
Vehicle Speed = 98.00 (closed course, professional drivers only)
Engine Speed = 5,078.0
Base Spark = 15.00
KNK ST RETARD = 3.00 (lightest colored trace)
Actual Spark = 14.50
Edit #2 - picked this up off another post on this forum.
"Knock Retard, this the amount of timing removed (in degrees) due to knock (detonation/ping). The knock sensors can in rare cases pick up other harsh engine noises as well, if this is the case it is recommended to fix the cause of the noise before proceeding.
You basically always want the knock retard to read zero under wide open throttle conditions, it is normal for it to show some KR when stomping on the throttle and also during the shift.
Monitor the spark and the knock retard pids under wide open throttle and see if you have any knock retard, anything higher than 1 should be adjusted in the respective timing range in the Predator , if the knock is severe, 5 deg plus, try lowering spark by 10%, if less than 5 deg, try 5%. Make another wide open pass and monitor the same pids and basically keep doing this until you seen no knock retard."
Now the basic question is if the above applies to the KNK ST RETARD or the KNK LT RETARD? The long term retard PID was basically zero if I remember correctly.
