07 2500 hd 6.6 - installs but wont run right at all !!
junior38320
ok so i bought the predator from a friend and installed it on my truck. it dowloaded and everything but as soon as i went to take off, it stuttered then took off like scared cat , then died. does this everytime .... it seems as soon as i get close to 2000 rpms it does it . i put it back to stock and it runs fine. it did throw he code P0606 after this all happened. my buddy said he never had a problem with it on his and he has used it on few different trucks. any ideas???
Re: 07 2500 hd 6.6 - installs but wont run right at all !!
what revision do you have listed on the main page of the tool when powered up.
junior38320
v8r20 is what is currently showing when i plug it in....
needs to be updated to the attached version.
- u7186_dmx_lly_lbz-9r08.crom
- (767.45 KiB) Downloaded 824 times
junior38320
well i finally got things lined up n updated it n it worked. but i hate to inform ya i couldnt use the update u sent me... idk why but it wouldnt go through... i ended up gettin it to work with 9r08.... but thank you for the info and evrything !!!
