Key Fobs Range limited with Tuner plugged in
Matti
Post by Matti »
When attempting to unlock/lock the doors with the T-1000 plugged into the Jeep the range is so limited i literally need to be standing in arms reach of the vehicle for it to lock/unlock.
Unplugging the tuner and trying it again i can lock unlock from down the street.
Is this a known issue? :blowup:
Eat. Sleep. JEEP.
2011 Jeep JKU - D60's
ElJay
Re: Key Fobs Range limited with Tuner plugged in
Post by ElJay »
Big Known Issue. Diablo Will Tell You To Move The Trinity But It Doesnt Matter Where It Is, Once The Obd Cable Is Plugged In, The Rfi Interference Starts.
Pretty Sure This Is Against FCC rules.
Matti
Post by Matti »
Being a Hamm Radio guy i decided to add about 15 ferrite chokes to the Cable.
This increased the range about 40 feet.
still not perfect, im awaiting a response from the FCC
Eat. Sleep. JEEP.
Matti
Post by Matti »
:normal:
Eat. Sleep. JEEP.
snakebit
Post by snakebit »
Not only that but it will limit the reception on some of my FM radio stations also.
As soon as I unplug the reception is crystal clear! :?
dlayne2012
Post by dlayne2012 »
I wondered why I was experiencing this. I really hate to keep connecting and disconnecting it bc that will take a toll on the OBDII port.
2007 Ram 1500
Trinity, HO Cams, Volant CAI/Custom Ram Air, Power Wire, JBA Shorty Headers, Magnaflow Y-Pipe, QTP E-Cutout, Magnaflow 14", Flexalite 183 E-Fan, 180 T-Stat, 08 Intake Manifold, F&B 72MM TB, SRT8 IAT Sensor, Mag-Hytech Covers, 4.56 LSD, ATI Super Damper 25%, BT Catch Can
gesjr
Post by gesjr »
Does the same thing on my 08 ram. i too am wondering about beating the hell out of the obd port by plugging and unplugging. Here in maine i depend on my remote start to warm the truck in the morning but hate to keep unplugging my trinity.
marcus23
Post by marcus23 »
I ageee with gesjr I installed a tuner on my 2011 ram and my remote start stopped working....bummer
DankMank
Post by DankMank »
So the programmer has to be plugged into the OBD port for it to work? You don't simply upgrade, remove, and throw it in the drawer?
garrett
Site Admin
Post by garrett »
try moving the location of the trinity. the cable may be causing interference if routed close to the module for your keyless entry.
Matti
Post by Matti »
You can't move the obd port
Reason: foul language
Eat. Sleep. JEEP.
Matti wrote:You can't move the fuckin obd port
hes not asking you to move the OBDII port, although, that is perfectly doable, lots of people relocate them for various reasons.
He suggesting that the location of the Trinity (where it is mounted) be moved, as it is likely sitting very close to the receiver for the remotes.
Matti
Post by Matti »
The issue is the cable not the tuner, as the issue happens even when the cable is plugged in alone.
It's an issue with the lack of shielding in your cable
Eat. Sleep. JEEP.
johnny248
Post by johnny248 »
OMG....this is insane....
I've noticed that the keyless range is has been terrible in my '11 Ram. I have to be about 20' away from it to remote start with the factory remote keyless/starter. I never once put two and two together. I unplugged my cable and Trinity and it works fine. Although this is a crazy weird problem, I'm glad someone figured it out. Now, if I can only keep my DS plugged in and keep my range....
'11 Ram 1500 Quad Cab 4x4 5.7l Hemi
BRR
Post by BRR »
It's funny I stumbled across this topic..
I'm experiencing the same issue so first I replaced the key fob battery thinking that was it, then I thought the fob itself may be failing until I read this topic. This is exactly the same issue I currently have, has someone tried to wrap the cable with some type of shielding to see if the issue goes away?
