2014 GM 6.2 support?
John_chadra1
Is support for this available yet? I see you can order from the site with the 6.2 option now, is that a green light????
Re: 2014 GM 6.2 support?
We have added several 6.2 cals.
if its not supported, the tool will read it out and ask you to send it to us, and we'll add it asap.
John_chadra1
I have a 2014 Sierra 6.2. I have a question about the throttle booster. I understand how it works, I have it set to 10 simply to lessen the effort to make the truck downshift. My question is that since it's set to 10 and it opens that much quicker.... does that make the last 10% or so of the actual gas pedal useless? I had my last truck tuned also and it didn't seem to gain anything past 85-90% throttle.
John_chadra1
I also wondered what the shift RPM was set at for the Diablo tune? Both in and out of Tow/haul mode.
no, we simply increase the table by 10% over stock, so it reacts 10% quicker vs throttle input.John_chadra1 wrote:I have a 2014 Sierra 6.2. I have a question about the throttle booster. I understand how it works, I have it set to 10 simply to lessen the effort to make the truck downshift. My question is that since it's set to 10 and it opens that much quicker.... does that make the last 10% or so of the actual gas pedal useless? I had my last truck tuned also and it didn't seem to gain anything past 85-90% throttle.
we dont change shift points in the tunes.John_chadra1 wrote:I also wondered what the shift RPM was set at for the Diablo tune? Both in and out of Tow/haul mode.
John_chadra1
Thanks, Truck is running great with no issues!
enjoy
John_chadra1
I have noticed that my 1-2 shift is far slower it seems than any other shift beyond that. Almost feels stock when the rest are much quicker and far more positive. It seemed better when I ran the Hard shift tune. Any advice?
2014 Sierra SLT All Terrain 6.2 4x4
modify the tcm tune and make the shift time quicker...
John_chadra1
How do I do that? I only see pressure change, the only shift RPM change is at WOT.
John_chadra1
It says you can adjust each shift point by RPM and MPH at WOT and Part Throttle... I do not have these options. I have the latest update as of 11:00am EST today.
- Untitled.jpg (224.42 KiB) Viewed 4450 times
John_chadra1
we'll have to address that, there is no need for an MPH setting on your truck.
