Can't fine my custom tunes in the "tunes" file!!!
A.H.Y
Post by A.H.Y »
Hey.... This is my first post here :)
I have an Intune i-1000 to tune a 2007 Chrysler SRT8 with Bolt on and cam shaft mods.
I tuned the car with a custom tune in a local workshop. In the first tune, the performance of the car wasn't that good. Another custom tune was send by the workshop. But first, I wanted to delete the old custom tunes, I opened the Intune drive and I found the normal "logs" and "tunes" folders and an info file, but the "logs" and "tunes are EMPTY!!
Anyway, I drag the new custom tune file into the "tunes" folder - for the moment the new custom tune file is there - but when I close the folder and re-open it, it disappeard!!
I reconnected the intune and go to the "tunes" folder but nothing there (again empty)!
I drag the new custom tune file again but a message appeared in the intune screen said: "Custom Tune (Name of the custom tune file) is already loaded. Continue".
I formatted the intune drive but with no use!!
I updated the intune device but with no use!!
Any help in this!!??
I need to erase all old custom tunes and put only the last custom tune file as recommended by the workshop.
NOTE: the original backup of the car is already restored i.e. Intune is in a stock condition.
Thank you in advance
Re: Can't fine my custom tunes in the "tunes" file!!!
to delete previous tunes from the intune, you'd go to Settings - Advanced - Erase Custom Tune
there are no files in the logs or tune folder on the intune, because you restored the original backup stock tune to the car...
before you import the new custom tune to the intune, you will have to let the intune save the original backup stock tune into itself first...
