I-1000, gears and afr help.
Posted: Thu Apr 10, 2014 5:39 pm
by cooper1965
Re: I-1000, gears and afr help.
Posted: Thu Apr 10, 2014 6:03 pm
post the tunes from the tunes folder and we'll set up the gears for you in a custom tune.
Posted: Thu Apr 10, 2014 9:44 pm
by cooper1965
Thank you for such a quick reply Mikel, I will post those file's first thing in the morning. Thank's again!
Posted: Fri Apr 11, 2014 8:16 am
by cooper1965
Here are the files you requested.
Posted: Fri Apr 11, 2014 9:20 am
by johan
Here you go
Posted: Fri Apr 11, 2014 10:21 am
by cooper1965
Thank you johan!
Can anyone provide some insight into my other question about adjusting the injector slope without using any AFR data?
Posted: Sat Apr 12, 2014 8:47 am
by 06MonteSS
if it's saying you need to adjust -12%, you have issues.. you shouldn't be running that lean for only a cai mod...
sounds like you have an air leak or leaks somewhere...
check everything under the hood.. make sure the cai is fully together, all clamps/bolts TIGHT so no air leaks there, all vent/breather tubes connected where they should be, etc...
