09 Challenger R/T need rear o2 disabled
dwsteele4012
Post by dwsteele4012 »
I need to see what I need to do to have my rear o2 sensors disabled. I only run the 93oct CAI tune and only want to modify the rear o2 sensors. I knew on my old Charger I had the option, but this version of the Predator does not shoe it. I have two predators, my old one and my newer one. the old only shows going up to 2008, so I couldn't just use it to turn them off. Any help would be great. Thanks
Re: 09 Challenger R/T need rear o2 disabled
Option is no longer available because its illegal to modify any emissions equipment. You'll have to contact a CMR dealer to do if you must have it done.
Nebula
Challenger SRT Need rear O2 disabled
Post by Nebula »
I live in Canada, its not illegal to modify it here. I assume though because you are US based you still can't do it?
I've been throwing CEL codes since installing high flow cats. I just ignore them but that could lead to something worse if I missed a real CEL problem.
Re: Challenger SRT Need rear O2 disabled
Nebula wrote:I live in Canada, its not illegal to modify it here. I assume though because you are US based you still can't do it?
You sure its not illegal? Modifying the emissions system is normally a no-no. You can have the codes turned off by a CMR dealer.
