DSI missing preloaded tunes?
DizzySRT
Post by DizzySRT »
So I purchased a diablo sport intune and read that there should be some preloaded tunes for my dodge neon srt4. When I tried to write a new tune it didn't give me an option to pick 91 or 93 octane. Another problem I'm having is updating the drivers. Also what's the latest firmware? I'm on 1r01h. Is that the latest?
info.xml
(435 Bytes) Downloaded 253 times
Re: DSI missing preloaded tunes?
Man, that tools been sitting around for a long time, needs to be updated desperately.
First, restore the stock tune.
Save this 1r01i file to the intune drive, let it reboot, then save the cd rom file and do the same, then let the updater run and it will take 45 min or so to update everything.
cdrom-1r01p.itf
(5.39 MiB) Downloaded 292 times
intune-1r01i.itf
(1.48 MiB) Downloaded 340 times
DizzySRT
Post by DizzySRT »
Alright I'll try that thanks!
DizzySRT
Post by DizzySRT »
Alright so I updated it and everything seems to work fine although it still doesn't give me the option for 91 or 93 octane tune. Also the driver fails to install every time.
stage cal?
they may just get the 91 min diablo tune.
post the info file.
DizzySRT
Post by DizzySRT »
is there anyway i can get the latest drivers?
info.xml
(1.74 KiB) Downloaded 318 times
DizzySRT
Post by DizzySRT »
its trying to do a group update but fails?
garrett
Site Admin
Post by garrett »
Plug the tool into the computer, exit anything that may pop up. Go to the start menu on the computer, click on Computer. There will be a drive labeled “cdrom Diablosport” on the device. Right click and choose open. After it opens you will see a program labeled intune.exe. right click and choose run as administrator. The updater will open, and auto update.
DizzySRT
Post by DizzySRT »
I'm still unable to find the drivers for this device. I tried on windows 8 and 7.
open diablosport cd rom drive, right click the intune.exe and run as admin to let drivers install.
bling
Post by bling »
there is no file called intune.exe on my i1000. cdrom is blank
Check the other drive. inTune is recognized by Windows as 2 different drives. If its not on one, it'll be on the other.
intune.exe file is on the "Diablosport" cd drive that shows up when you connect the tool to your PC....
bling
Post by bling »
there is no intune.exe anywhere in the tool. theres a diablo.iso.pz that is 0 bytes in size. i cant register the tool to get an update without this software?
delete the .pz files.
intune cd rom lives on the diablosport drive.
