I bought a inTune second hand from a guy that didn't understand how to use it. It looks like someone was mistakenly using the usb drive side of the inTune for Itunes mp3 storage. I've deleted that but there are a few other files and folders that I'm not sure should be there. If I format the USB side of the inTune will it auto-restore on an update and build the file structure required or is that a big no - no? Is there a way to get a listing of the proper files and folders that should be on the USB side of the inTune? There are no tunes loaded yet, I want to be sure that the intune is exactly as it should be before I start swapping tunes around.
Is there anything else I should do before starting to load tunes? (He was using it for a '07 Dodge and I'm going to use it on '13 GMC)
Cheers
USB drive
Re: USB drive
intune drive should have tune folder, logs folder, runtime folder, and a file called info.xml
Re: USB drive
Thanks, there were quite a few other files that I didn't think belonged.
Re: USB drive
Can I request a registration file now please?
- info.xml
- (2.61 KiB) Downloaded 290 times
Re: USB drive
save this to the intune drive to finish up the registration.
- registration.itf
- (859 Bytes) Downloaded 256 times
