can you check this logs ?
I'm having troubles with knock
I tried 91 tune 87 tune in all tunes I have knock
I use only premium fuel 92 oct
I'm having 13 knock st
I'm a little scared about it
Mods
CAI airaid
catch can
T-stat180
09 RAM 5.7 knock
sarah_ima64
09 RAM 5.7 knock
- PCM_68037624AH.drg
- (102.17 KiB) Downloaded 192 times
- PCM_68037624AH_Perf_87oct_modified.drg
- (2.25 KiB) Downloaded 160 times
- (102.17 KiB) Downloaded 175 times
- PCM_68037624AH_Perf_91oct_modified.drg
- (2.25 KiB) Downloaded 157 times
- RAM_09_91.LOG
- (484.49 KiB) Downloaded 156 times
- RAM_09_87.LOG
- (498.91 KiB) Downloaded 158 times
2005 RAM 1500 Daytona : Diablosport Trinity, CAI Airaid, Headers JBA, Catback Borla.
2009 RAM 1500 SLT 4x4 : Diablosport Trinity, CAI Airaid, headers JBA, Catback Flowmaster.
2011 RAM 1500 Laramie 4x4 : Diablosport Trinity, CAI Airaid, Catback Magnaflow.
Re: 09 RAM 5.7 knock
add some fuel in the rpm ranges where you see the knock.
sarah_ima64
how much add fuel ?
Can I start 5% adding fuel ?
Also in part throttle the sensor read 3.5 knock st
start at 5%
sarah_ima64
I already solved the knock but I had to add 14% fuel and now the sensors always read 0.00
good job.
The ST an LT knock read 0 ALL the time? At both part throttle and WOT? If so then you are perfect. 1-2 ST is acceptable.
sarah_ima64
dtru1222 wrote:The ST an LT knock read 0 ALL the time? At both part throttle and WOT? If so then you are perfect. 1-2 ST is acceptable.
Yes all the time read 0, in 30 minutes, with 5 wot
