09 RAM 5.7 knock
Posted: Sun Aug 03, 2014 11:24 pm
by sarah_ima64
can you check this logs ?
I'm having troubles with knock
I tried 91 tune 87 tune in all tunes I have knock
I use only premium fuel 92 oct
I'm having 13 knock st
I'm a little scared about it
Mods
CAI airaid
catch can
T-stat180
Re: 09 RAM 5.7 knock
Posted: Mon Aug 04, 2014 10:14 am
add some fuel in the rpm ranges where you see the knock.
Posted: Mon Aug 04, 2014 1:28 pm
by sarah_ima64
how much add fuel ?
Can I start 5% adding fuel ?
Also in part throttle the sensor read 3.5 knock st
Posted: Mon Aug 04, 2014 2:33 pm
start at 5%
Posted: Mon Aug 04, 2014 3:40 pm
by sarah_ima64
I already solved the knock but I had to add 14% fuel and now the sensors always read 0.00
Posted: Mon Aug 04, 2014 4:53 pm
good job.
Posted: Thu Aug 07, 2014 10:08 am
by dtru1222
The ST an LT knock read 0 ALL the time? At both part throttle and WOT? If so then you are perfect. 1-2 ST is acceptable.
Posted: Fri Aug 08, 2014 5:03 pm
by sarah_ima64
dtru1222 wrote:The ST an LT knock read 0 ALL the time? At both part throttle and WOT? If so then you are perfect. 1-2 ST is acceptable.
Yes all the time read 0, in 30 minutes, with 5 wot
