Page 1 of 6
2014 Dodge Challenger SXT and Traction Control
Posted: Mon Aug 11, 2014 3:10 pm
by Belrix
Hello
I have a 2014 Dodge Challenger SXT and when I try to disable the traction control I get a message after 10% that says "Unable to Update Traction Control".
I have updated my I-1000 to the latest software.
Any ideas?
belrix
Re: 2014 Dodge Challenger SXT and Traction Control
Posted: Mon Aug 11, 2014 4:49 pm
can you provide us your calibration ID (options/troubleshooting/show calid)
Posted: Tue Aug 12, 2014 1:05 pm
by Belrix
I guess I'm a little slow this morning, can't find the calibration ID on the tuner or in the software!
Here is the info from the info.xml file:
cal_id PCM='68214241AG'
Is this what you needed?
Thanks for the reply
belrix
Posted: Tue Aug 12, 2014 2:49 pm
thanks, we're checking it out.
Posted: Tue Aug 19, 2014 10:54 pm
by billfromislip
Hmm... This sounds familiar except mine is a 2014 Charger R/T. Has never worked and I guess they're still working on it since I still haven't heard anything back from my post on July 9th.
Good luck!
Posted: Mon Sep 08, 2014 3:15 pm
by Lcbart123
Uh Oh - My 2014 SRT traction control hasn't worked since I first hooked up my Trinity about a month ago and changed the throttle response. Restored to the original tune and still no traction control. Taking it to the dealer on Thursday 9/11. Hoping they don't say it's my fault due to the tune.
Posted: Mon Sep 08, 2014 9:40 pm
by Brian13RT
I have the exact same issue on my '13 Charger R/T Road and Track. I'm still waiting on a resolution as well.
TRACTION CONTROL
Posted: Thu Sep 11, 2014 1:41 pm
by Brian13RT
Are there any updates regarding the inability of my DCX to disable my traction control? Even though this isn't something that I want to do every day ... I still want to have the ability to do it whenever I desire to. In my opinion my DCX is broken since there is a function that doesn't work.
Posted: Thu Sep 11, 2014 2:19 pm
would you like a customtune for now that will disable TC when loaded?
Posted: Thu Sep 11, 2014 9:58 pm
by Brian13RT
I currently have the 91 time installed with modified parameters (20% throttle boost, disabled MDS, etc). Will the cust tune for disabled traction control also be a 91 tune with the modified parameters?
Posted: Fri Sep 12, 2014 8:26 am
yup,post the last tune written please.
Posted: Mon Sep 15, 2014 1:23 pm
by Brian13RT
Here is my last tune written. It is the canned 91 octane tune with the following modifications:
- Disabled MDS
- Increased Top Speed Limiter to 190 mph
- Increased Throttle Response 20%
- Added 5% (Rich) WOT Fuel to all 3 RPM Ranges (due to having an LMI Hammer CAI)
Also, since it isn't letting me disable Traction Control I also posted my info.xml file as well in case you need it.
Please let me know when the custom tune is ready (which will reflect the above 91 octane tune + disabled Traction Control).
Thanks!
Posted: Thu Sep 18, 2014 12:21 pm
by Brian13RT
Any progress on that custom tune yet?
Posted: Thu Sep 18, 2014 2:29 pm
sorry for the delay, give this a shot.
Posted: Fri Sep 19, 2014 9:12 am
by Brian13RT
Thanks, I appreciate it. I loaded the tune and everything went good. I took the car out and was rolling at about 25mph when I put it to the floor. The car downshifted and the rear tires broke loose. It never did that before so I assume the custom tune did its job.
My only question now is in regards to the lights that illuminated on the dash. There are only 2 lights on and I guess I was expecting 3 -- so I want to make sure that everything is truly fully disabled (Traction Control, as well as Electronic Stability Control).
The only 2 lights that are illuminated are the ABS light and the light that shows a car leaving black marks behind it. The light that shows a car leaving black marks behind it and also has the word "OFF" below it is NOT illuminated. I guess I was expecting to see all 3 lights displayed (ABS light, car leaving black marks behind it, AND car leaving black marks behind it with the word "OFF" below it).
I guess I just want to make sure that Traction Control and Electronic Stability Control are both fully disabled by this custom tune. For now I will load this tune when I want to have a little fun and load the other 91 tune that I had previous to this when I want T/C and ESC enabled.
Please let me know if the results I'm having are correct (in regards to the dash lights), as well as when a fix is available that will resolve the issue of Traction Control not being disabled in the Quick Adjust menu. Ideally, I want to be able to go into the Q/A menu and disable Traction Control that way.
Thanks!
