In trying to check tunes being written to truck. I only show the backup and not any of the custom tunes I have uploaded. I know that the the custom tunes are being written in because i get the countdown and clock reset (but errors after trying to install tcm portion..but that's another issue) plus It won't run on stock tune anyways. Any ideas why it won't show the actual last tune installed?
thanks,
-fred
Doesn't show actual "Last tune Written"
- chefred112
-Fast Freddie-
05 Hemi QCSB
392 - 232/238 cam /heads/lt's/true duals/dual e-cutouts/cai/efan/3.92 gears/2600 stall verter/180 tstat/cat deletes
old 5.7- 214/218 cam/heads/lt's/true duals/dual e-cutouts/cai/efan/4.56 gears/2800 stall verter/180 tstat/cat deletes
05 Hemi QCSB
Re: Doesn't show actual "Last tune Written"
Likely due to the TCM failures.
Too bad we dont have the option on Predator like inTune to flash only one or the other module if you choose.
- chefred112
Hi Mike,
Are you saying if I upgrade to Intune (or Trinity)...that this is something that can be 'fixed' for that quirk of not reading tcm...or actually last tune written?
thanks, fred
thanks, fred
-Fast Freddie-
05 Hemi QCSB
05 Hemi QCSB
inTune allows you to simply load a file to the PCM and skip TCM, or TCM and skip PCM, or both, or neither....
- chefred112
I can at least load the pcm tune... it's interesting that I can't install the tcm portion but can still see the tcm calid. I'll try some things over the weekend.
-Fast Freddie-
05 Hemi QCSB
05 Hemi QCSB
