Update unsuccessfull
Posted: Thu Sep 25, 2014 8:09 pm
by mesanchez23677
i have a 2014 Dodge Challenger rt and while installing the tune in my car, it tells me to turn off the ignition and turn back on. After I try to turn it on the car doesn't start. Then a message pops up saying calibration unsuccessful, calibration update via Dsdl. I try to plug it back in to the computer and it stays stuck on that screen. I was able to reset the car and get it running again.
Re: Update unsuccessfull
Posted: Fri Sep 26, 2014 9:33 am
pop the button out and use the key, it will go much smoother :)
Posted: Fri Sep 26, 2014 10:58 am
by mesanchez23677
From the research I've done it seems you can't start the car with the emergency key. The ignition port to it doesn't pop out. Unless you know something I don't?
Posted: Fri Sep 26, 2014 11:10 am
by mesanchez23677
Well I've found out how to pop it off. Thanks for the help and quick response.
Posted: Fri Sep 26, 2014 1:11 pm
good deal.
Use the key anytime you are programming, otherwise the button is fine :)
