Jeep Wrangler 3.6 cut off rpm
ma7romal7ob
Hello ...
I have Jeep Wrangler 2013 engine 3.6 already have Diablo Sport Trinity programming custom and I would like to add programming for cut off rpm ...
I would ask about how I can open cut off rpm ?
Thank you wish to respond as soon as possible ..
Re: Jeep Wrangler 3.6 cut off rpm
if you are asking about raising the rev limiter, yes, that can be done with our tuners.
ma7romal7ob
Already I am opened rev limiter ..
But I want cut off RPM last Limit
when the car stoop or driving in the road..
Same this car in the video
http://instagram.com/p/t5a0KPRt5T/
http://instagram.com/p/tVkM5mEMns/
Sorry Mikel but that is NOT totaly true or maby for 2012 models only because they dont have the autostick on thire jk's and if they select 1 it stay 1 but for us as 2013++ jk's if we hold in 1 it will shift automaticly to the 2nd gear when it reach 6400 RPM so nothing will happen if we rise the rev limiter and sadly diablosports dont offer us autostick delete like challengers **we have the same TCM same part number but dont know why no support for us!! am not talking about changing shift point "i know that can't be done" but at lease we want to have the option to disable the autostick.mikel wrote:if you are asking about raising the rev limiter, yes, that can be done with our tuners.
regarding the guy who is asking about fast rev cut off like the 2nd video link I think the answer is no, i tried we still have normal rev limiter as 6400. but with other tuners like bully dog the can as seen on the link, we hop we see improvments in the can tunes for our pentastars as the other tuners.
post the tune file, I will check it out, all you have to do is ask, rather than say I am not telling the truth.
No offence meant from my side i was just trying to clarify my issues from my humple experience with the trinity.mikel wrote:post the tune file, I will check it out, all you have to do is ask, rather than say I am not telling the truth.
I will post the tune file some time tomorrow and i hope we can solve the issue.
Thanks & regards.
Mikel, please find the tune file.
- PCM_68149808AC_Perf_93oct.drg
- (2.25 KiB) Downloaded 474 times
- PCM_68149808AC.drg
- (91.88 KiB) Downloaded 545 times
there are no changes to the limiter here, can you please adjust it with the tool then load it to the vehicle and get me that last tune written?Yes wrote:Mikel, please find the tune file.
its all really adjusted to 6800 in the tune itself, but I will do what you say and will let you know.mikel wrote:there are no changes to the limiter here, can you please adjust it with the tool then load it to the vehicle and get me that last tune written?Yes wrote:Mikel, please find the tune file.
I just tried rising the rev limiter but something weird happend!
Before its was 6800 then it become 6600 but that's okay for me at least not 6400, but the worst part is there were no changes except when I select the manual mod it shift 5900 in the first gear then every shift after first one is the same 6400!
I will post last tune when I get home and if you want I will sent data log file.
you cant change the shift points, is that what you are trying to do?
I just want my car to hit the rev 6600 rpm in driving or in neutral after I adjust the parameter and set it as 6600 rpm. Otherwise why we should have rev limiter option that we can't use!mikel wrote:you cant change the shift points, is that what you are trying to do?
So the answer is No, we can't raise the rev limiter in auto jeep wrangler 2013+
you can raise the limiter to the moon, if it shifts at 6000 rpm or so, it will never get there.
please tell me how!
at least in neutral
at least in neutral
