monitoring help
Post questions about your Trinity in your GM diesel applications here.
Duramax33
monitoring help
Post by Duramax33 »
ok first of all the tuner is great, lots of power, the problem I am having is when I go to the monitoring option it says GM-GAS, and it only gives me the option for a gas truck, I have a 04 Silverado 2500hd 6.6 duramax lb7, Tool: trinity
Serial: 6ODXCF2-3
Type: gm_j1850
Part: gm_j1850
Version: v.1r13
Date: 08/28/2014
Protocol: 2.0
RPC Protocol: 1.6
Duramax33
Re: monitoring help
Post by Duramax33 »
no help with the tech support, I have not 1 diesel option when I make my own layout, I hooked it up to my friends 06 LBZ and it has the layouts for that model, is there a way I can have it sent in for a software add on for the 04 LB7, it is up to date, I just feel like I have been ripped off, $500 for just a few tunes, I want to be able to read what my truck is doing also
Re: monitoring help
this is a bug we are looking into, but if you create your own layouyt in logging it will work fine.
Duramax33
Re: monitoring help
Post by Duramax33 »
Yes it does work fine for engine temp, RPM, I alread have that on my dash, I was hoping you all could make it work for the 04LB7 like it does for the LBZ duramax, thanks a bunch.
Re: monitoring help
I understand, what I am suggesting is you should be able to go in the logging menu, select create a new layout, and make one using the diesel specific pids that you want to monitor.
Re: monitoring help
I had a chance to test this on a buddys 01 Duramax the other day, and when I selected 2001 Chevy 2500 6.6 from the change vehicle type menu, it gave me the 01-04 Duramax layout, please give that a shot, and try the restore default layout option if that does not do it.
Re: monitoring help
fix for this issue is attached here, sorry for the delay
trinity_gm_j1850-1t13cb_update.crom
(1.43 MiB) Downloaded 770 times
Return to “Trinity GM Diesel”
