Going from 87 to 93 tune.....
neonhomer
Post by neonhomer »
Well, I was told I can get better mileage from using the 93 tune over the 87 tune. Question is, what is the procedure from going to the 87 to 93 tune. Obviously I need to run 93 octane gas (waiting until my tank is close to empty to fill it with 93), but do I need to wait for a period of time before going from the 87 tune to the 93 tune?
Should I completely uninstall the Predator when going between 87 and 93, or just go to the 93 tune?
NeonHomer
1996 Jeep Grand Cherokee I6 4.0
Grumpy_Aero_Guy
Post by Grumpy_Aero_Guy »
I simply ran my tank down to about 7/8 empty, filled up with 93, loaded the 93 tune (from DS 87 tune) and had no problems.
After burning about a 1/4 tank of the 93, I filled up with 93 again, just to be sure.
Didn't notice ANY issues.
You can go straight from the 87 to the 93 tune. Your original back-up is still in the predator and will not be molested by switching from 1 Diablo tune to the other.
In my case, if there was a mileage improvement, it appears to be marginal with the 5.3 in my NBS Sierra --- of course, the 93 tune appears to have made my right foot a little consistently heavier for some reason... :twisted:
With summer blend gas, it seemed like the mileage improved slightly more than with winter blend gas.
The performance improvement between the 87 and 93 tune, however, in my mind was very significant and palpable easily.
Enjoy!
DSLogRedux.com
neonhomer
Post by neonhomer »
Fuel here is $2.99 a gallon for 87, and $3.19 (or so) for 93/premium... If the performance and mileage gains are not that much, then what's the good of going to the 93 tune then?
NeonHomer
The performance of the 93 tune will blow the 87 tune out of the water...gotta pay to play!
neonhomer
Post by neonhomer »
Now to rehash a old thread.... Since I have my trims adjusted, when I go to the 93 tune, will I have to readjust the trims, or will they carry over to the 93 tune, and vice-versa?
NeonHomer
on my model predator (U7191), when you switch tunes, it prompts you and tells you that you're changing to a different tune, and asks you if you want to "Reset All Parameters?"
if you select YES, it will wipe out all your previous adjustments... if you select NO, it applies your existing adjustments to the new tune you are installing.
01Z
Post by 01Z »
06MonteSS wrote:if you select YES, it will wipe out all your previous adjustments... if you select NO, it applies your existing adjustments to the new tune you are installing.
Even if those adjustments conflict with the new tune?
2001 Camaro Z28 - GM LS6 heads and cam. SLP cold air LID & Loudmouth exhaust - n2o...
U7198
GM02 Predator
Software 2.13
Hardware 1.01
1st6.0GTO
Post by 1st6.0GTO »
I'm kinda wondering the same thing, to a point. The thing I just thought of is my car says to put 93oct in it with a stock Pontiac tune, Right on the gas door. So if I am already running 93 stock then I'm starting to wonder if I modify the factory tune if I will see better timing numbers.
Sorry for the partial thread jack.
http://diablosport.com/index.php?name=P ... pic&t=5397
04 GTO 5.7 A4, K&N drop in w/mod'd airbox, SLP LM2, JBA Catless Mids, P&P TB, Lightly Ported MAF(.040) Then Polished & Descreened, MSD 8.5 super conductor wires, AC Delco Iridium plugs, U7193 Predator(tuned by me)
yes... for example.. the default tune settings all have the adjustable parameters set at 0 - in the middle... if you made adjustments to your injector slope to -5%, and you install a different tune and choose to keep the previous adjustments, it will make that -5% adjustment to the injector slope setting of the new tune you are installing.
neonhomer
Post by neonhomer »
My LTFT's were still around +0.7 or so with the new programming...
I did a couple of WOT runs, and got around a 870 or so on the downstream sensors....
NeonHomer
Stevens07
Post by Stevens07 »
Your not kidding when you say the 93 tune blows away the 87 tune. I just switched my Vmax back to the 87 tune, and it's night and day how the truck runs. I hope to get a mileage increase, or I'm going back to the 93 tune.
Steven
2007 GMC Sierra SLT Vmax. 4.10 gears, Bedrug, Boss MT100 20x8.5 wheels/Kumho STX tires, Extang Bed cover, Light of fire, Denali Grill, GM Performance Intake and DiabloSport
neonhomer wrote:My LTFT's were still around +0.7 or so with the new programming...
don't go by the O2 sensors at all...
just get your fueling dialed in via inj. slope adjustments so that you're average ltft's are at 0 to -2, then leave the PE settings alone at the 0 default setting and you'll be all set.
Stevens07 wrote:Your not kidding when you say the 93 tune blows away the 87 tune. I just switched my Vmax back to the 87 tune, and it's night and day how the truck runs. I hope to get a mileage increase, or I'm going back to the 93 tune.
Steven
Mileage will likely stay about the same between the two tunes...
Stevens07
Post by Stevens07 »
I can't keep my foot out of the gas with the 93 tune..... so I'm sure I'll see an increase with the 87 lol
Seriously, both should yield better mileage?
Steven
Stevens07 wrote: Seriously, both should yield better mileage?
Steven
Yes.
