urgent help please
Wallejk
urgent help please
Post by Wallejk »
ok so i took my car in for a repair and after 3 days they lost the keys, they gave me another key that they programmed till they order me a new one,
i forgot to remove the tune when i took it in. now when i try to tune the car it says please connect to pc for calibration update. i plug it in it says no update but when i plug it in the car it keeps asking the same thing!
could the key programming mess with my tune or change anything that has to do with the tune ?
help!!
Even tho the diablo tuner is synced with my car and shows the same vin it keeps asking me to update calibration. The pc says it's up to date..... Idk what to do man.... I want to restore my original car backup. I saved it on the computer and the tuner is synced with my car and I can see my original backup on the diablo tuner when I connect it to the pc, how do I go about doing that ??
Please if you know a way to force the original backup on the car I would be greatful, even if the new key will be reset.
I don't mind
I'll park infront of the dealer and try to restore the original backup, incase the key doesn't work I'll get the dealer to do it on the spot and reprogram the key
and i just want to state that my stock modified tune is still on the car, i only disabled MDS and its still disabled. so they didn't completely re flash the PCM. i think the key reprogramming must of disabled something. i try to do force backup in advanced tab, it said check calibration update :(
i have all my original backup files. they are taking the car back in a few days for a grille change and new key programming.
help me get my original backup on the car please!
Update:
they called today and said they found my key, if i use my orginal key, could it work ? cause my tune is still there i figured no way the pcm was flashed
Re: urgent help please
they flashed over the tune, fax or email proof of the dealer service then call with the tool powered up and we will reset it then you can do the cal update and start over.
Wallejk
Post by Wallejk »
ill call you guys today but i didnt know what email to send my papers to so ill post them here
Vas@Diablosport
Post by Vas@Diablosport »
got ya reset by phone.
No, i don't work here.
Wallejk
Post by Wallejk »
thank you!
its all good to go.
