Question about changing canned tunes
Posted: Wed Apr 08, 2015 8:35 pm
If I copy, rename, and save a canned tune as a custom tune then go into it to make changes will I be starting with the settings from the tune or from stock. Example: renamed "hard shift" and then uploaded it and now wanting to go in and adjust pressures. when I open the pressure adjustment setting is it at the "hard shift" setting?
So, if I add 10% will that be on top of the hard shift tune?
If that is the case, where can I find out what the settings are in the tunes so we can make adjustments?
