'08 Silverado - Mod stock to 87 Tune w/ stock TCM
Mossyoakglock
Post by Mossyoakglock »
I am currently running the "modified stock tune" with just AFM turned off. I'm thinking about loading the canned 87 tune in the next few days. I want to obviously keep AFM off but I also want to keep the stock TCM tune since I am currently running the Vette servo and don't want the shifts any firmer. What steps do I need to take?
Do I just plug up the intune, click "write vehicle",select the 87 tune, go into the adjustable parameters (when it asks if I want to modify the tune) and turn AFM off? What do I do when it asks about the TCM tune? Is there an option to keep the stock TCM tune or will it ask "tune TCM" or something and click no?
2008 Chevrolet Silverado
5.3L w/ 4L60E
2.5" level w/ 275/60R20 BFG KO2
Airaid MIT
Vette Servo
Re: '08 Silverado - Mod stock to 87 Tune w/ stock TCM
yes for the 87 tune/afm. that is correct...
and for the tcm, you'd just select modified stock tcm, that is just a copy of your stock/original tcm tune..
Mossyoakglock
Ok, thanks.
I wasn't sure because when I loaded the modified stock tune I thought there was something that said "load TCM tune" or something like that and I said no so I wasn't sure if it was the same when doing the 87 Canned tune.
5.3L w/ 4L60E
Airaid MIT
Vette Servo
if you select no, then it will not install any TCM tune at all, so the stock tcm tune will still be in the vehicle.
Mossyoakglock
Perfect. I don't have any sort of TCM tune on the vehicle now so I would assume selecting "no" would be the better choice. Or if I selected "modified stock tune" it would load the TCM tune which would just the stock tune if I don't mess any any of the adjustable parameters (or since I haven't previously adjusted anything).
5.3L w/ 4L60E
Airaid MIT
Vette Servo
