13 Dodge Charger R/T 91 Tune Error Code = 0x03270010 ?????
sbrister05
Post by sbrister05 »
I tried writing the 91 Octane to the new vehicle 2013 Dodge Charger R/T and at the end of the process this came up on the Intune Screen "Failed to read PCM original back up tune Error Code =0x03270010 and goes back to write vehicle screen just wondering where i should go from here and how to resolve this problem :blowup:
Re: 13 Dodge Charger R/T 91 Tune Error Code = 0x03270010 ???
can you post the info.xml file from the intune drive please?
Thans
sbrister05
Not sure what you mean info wise what do you need me to look up and post..... i was in process of 91 tune being installed when it got to 100% this message came up on the IntuneDCX "Failed to read PCM original back up tune Error Code = 0x03270010
there is a file on the intune drive called info.xml, i would like you to post that here please.
sbrister05
i think this is what you're looking for
sbrister05
just wondering if you you received it? :mrgreen:
sbrister05
still waiting on Reply 8)
everything looks ok on the device, have you tried it again to see if it is OK?
sbrister05
Ok so i did try it again and it worked but this times i went with the 93 tune, anyways i go into settings and try to turn off the traction control completely, it gets to 10% then says it failed? here's the info file
