U7131 application missing or corrupt after update
mjalstad
Post by mjalstad »
I have a U7131 that was running 9r06. I tried updating to 9r07 and the screen displayed "The application is missing or corrupt." even though the DSDownloader worked exactly like normal. I tried sending 9r07 again and got the same thing, then 9r06 and got the same thing, then 9r03 and got the same thing. I am very experienced with these but have never had this happen. Here's the tool info from DSDownloader:
Auto Connect is DISABLED.
Legacy Connect is ENABLED.
A tool was found on COM5 at 115200 baud.
XML RPC commands are AVAILABLE.
XML RPC protocol version is 1.60
Tool type = 'Predator'.
Serial number = '2130717088'.
Part number = 'u7131'.
CROM version = 'u7131-9r06 06/25/2010 06:19:47 PM boot3'.
Vehicle VIN = ''.
Vehicle Calibration = ''.
Original backup NOT saved.
Tool is Married FALSE.
Single user tool FALSE.
Using Class2 Protocol FALSE.
Calibration Updates are SUPPORTED.
A Calibration Update is NOT required.
XML RPC WILL be used for FRG transfers.
Tune compression is AUTOMATIC.
Tune compression is set to ENABLED.
Tool registration is NOT supported.
Tool does NOT support multiple ECUs.
Tool reports 1 ECUs.
Multi ECU Backups : 0
Marriage VIN :
Tool ID :
Desc :
Multi ECU Tuning : 0
Server:
garrett
Site Admin
Re: U7131 application missing or corrupt after update
Post by garrett »
http://www.diablosport.com/downloads/re ... -9r07.crom
please download and try the latest update once more. if you continue to have issues, please give us a call at 561-908-0040 ext 1
