Viewing adjusted parameters?
Andy H
Post by Andy H »
When I go back in to modify my stock tune again, It shows that I have disabled DOD. However when I got adjust tire size it always shows 36". I can adjust it to 34" and go back and it is on 36" again. Is there a way I can check to make sure it is writing what I choose to the ecm?
Re: Viewing adjusted parameters?
that is just the default selected choice in the setting.. it does not show what it is actually set to in the tune...
if you changed it before and installed the tune, then it is changed.. but it not reflected in the choices when you go back into the settings..
Andy H
Post by Andy H »
Ok, thanks!
Andy H
Post by Andy H »
One more question. If I just want to go in and change tire size only, can I just go to adjustable parameters? When I try that now I get, "Unable to resolve tune for LTW ()"
