2014 Ram 1500 "Vehicle not supported"
sentrek
Post by sentrek »
I ran the intune.exe and downloaded all updates, I know they took because when I plug it back in to pc and run update it says it is up to date.
When i try to write the tune to vehicle it says vehicle not supported.
2014 Ram 1500 5.7l Hemi
Re: 2014 Ram 1500 "Vehicle not supported"
please post the info.xml file from the intune drive.
sentrek
Post by sentrek »
info.xml
attached
it is not requesting na update here, did you click the green check mark on the screen when it asked for the update?
sentrek
Post by sentrek »
Yes, then tried it on vehicle and it didnt work, so plugged it back in and tried to run the update again and it said it was up to date. I can take a screen shot and post tonight so you can see what I see. Maybe I am missing something.
go to the truck again and if it asks for update click the check mark then post the new info file here please.
sentrek
Post by sentrek »
new file attached.
sentrek
Post by sentrek »
Attached pictures just so you can see what I am doing in order, in case I am doing something wrong.
they are numbered in order 1 thru 6. start at the bottom.
sentrek
Post by sentrek »
I got it working. I am not sure what the difference was, but I left it plugged into the computer for awhile, about 30 or so minutes and then clicked the update button and it finally updated. I think I am good now. Thanks.
