How do I register my InTune with a Mac?
Ottomatic
Post by Ottomatic »
Just got an InTune, but can't figure out how to register. Help please?
Re: How do I register my InTune with a Mac?
please post the info.xml file from the intune drive here.
svandevecht
need to register before able to update?
Post by svandevecht »
HI,
I am trying to update the InTune, but while loading, it mentions I need to register it?
Please explain how.
Sander
vig
Post by vig »
the easiest thing to do is run parallels on your mac and install windows. That's what i did and it's easy to update and use data viewer. You can find both programs online for free. If you don't want to get it that way, you can get a windows 10 serial number for $35 bucks on a site called getsoftwarekey DOT com. good luck
post the info.xml file from the intune drive here please.
darkspark
Post by darkspark »
i need to find my Serial Number as well
<tool_info>
<registration sn="14U7Z5H8GZ" status="0" tool_oem="DIABLO_D" updates="0"/>
<applications count="5">
<application name="vehicle" rev="2r01h"/>
<application name="updater" rev="missing"/>
<application name="gui" rev="2r01e"/>
<application name="installer" rev="2r01c"/>
<application name="logger" rev="2r01a"/>
</applications>
<databases dbnames="2r00" dtc="2r01a" vin="2r01g" gui="2r01c">
<database mfr="DCX" tune="2r01c" pid="2r01cc"/>
<database mfr="FORD" pid="2r01cf"/>
<database mfr="GM" pid="2r01ba"/>
</databases>
<last-connected vin="2B3CJ5DT4AH278751" mfr="DCX" calid="68052005AF"/>
<last-connected calid="05150626AAke3k0"/>
<licenses available="1" tuned="0"/>
<unsupported calid="68052005AF" vin="2B3CJ5DT4AH278751" oem="DCX"/>
<reg reg="9BN1anCy1pkoHxlv1Jea9nTaubGLWoS9v+bd2TlPngzoh1piW0yweouykm0khaeuyfYaqy1F28zMMdtoDOBt9Mw6CbWT5c5c2jQrTdQisucLMHw4txIOLUvJ/LQAbslU3hGoDnpQ5a8JXUIDekoMmcRP/wn5q8fTwHQQtJVWVwvoH/jnVlJnQN90DrzBW6n+vmgGCSuTwNXTuBGOB4snFuYTgqY40UZsxACSfzJN528SRE0Y5fQhFQEW18+83v7eey1X5sAGUAHttYduwABjA0CCPbxnkeqtROY1UqUjgi1czHw2AiLzZFV1T0gDr2W43iAKHQJulk04Q7FTp8lK2Y67jRupPN5Vw3++puE9wV43c7vjASVbwT994GU5arPlrYt3hv78YsK8rbTEQTMbJcnwNaTdILqIdKpjKe9aux2trNJTVjgzYXQ+2yE08Ds0Z0uIcKRR/1qkwVcI0qa+g1r+HWK8lafsGHgf0UH+J+Z8D8oUqPx/wCGpgZ7KA16WJprtt0Gz9De8mo20vyy5bfW3FK7rgrsMDN92XERLtbyl2gRMSZOXvOQpdkCa5X6S0Gnuevvm/uDjDTXyimUrn21XfAtJU2by/0P+yYRk2DNTlaQMg4WLaLD1koSzdmZdCmLCY/I+bgCIFx1RwsWPldqjxT6+vSp7jk0DNu5tu1g3FltIpUCBTgSP6m+LVRLCpXGK9o0GcOZd12MJO5YPv/a3WlpRg8KfnFs12TCQ+2AchpGSGN26ldY4d5/1Vcxho3XJGuQiiyrLVcjBdpf/WTvIEupfedGq5lmgtobgJ6VFHFz9hJc3+qcRcRVIZmFSnbfKZ7srr9YZRg5/d0g/5YZgBZARbXeFKDq/biKNH67sR7dPY7fhSNt7sJa34cFp5rPoWLMHF50Dw2ZjZLYheJHori+Eojj17EwHd4WyepCy2/HEoeHLgotYabaeO8yLqWP1qc3npaZ/k/562WEdE1i7XhKFWTwwjV+fXbUAF7K+2o5ARMrs/3vAGLaj+q/5+5eB4lTSkcwlOsu8ipFkE5u172yLdUnXvPhDiHiAodkd8XzgL0IY0ogo+37lVyhT8hxAt6ISP2vCCcU7Jaq+HbbuTuFa9Y1HNS+lT7zhCeQ0b0kGWw6XqhlX1q36xLc+NDrOWEUa7qj1BoH/"/>
</tool_info>
darkspark
Post by darkspark »
thank you
billabob
Post by billabob »
My intone also says i need to register but gives me no prompt. Can someone please assist?
ctehan
Post by ctehan »
<tool_info>
<main full_version='InTune-1r01h 03/29/2012 12:07:10 PM' sw_rev='1r01h' svn='4210'/>
<registration sn='CID5L4B-1' status='0'/>
<restore id='0' vin='2B3CA5CT4AH182006' bc='0'/>
<db mfr='GM' tune='1r01d' pid='1r01a'/>
<db mfr='DCX' tune='1r01f' pid='1r01a'/>
<db mfr='FORD' tune='1r01a' pid='1r01a'/>
<system_db dtc='1r01a' vin='1r01a' info='1r01a'/>
<license avail='1' tuned='0'/>
<unsupported calid='68052003AC' vin='2B3CA5CT4AH182006' oem='DCX'/>
<updates count='3'/>
</tool_info>
save this to the intune drive and let it import it to register the tool.
_registration.itf
(387 Bytes) Downloaded 345 times
tylerfegan
Post by tylerfegan »
I have tried to register a couple times and have heard nothing back. Could I get my device registered here is my info.xml
<tool_info>
<main full_version="InTune-1r04i 08/03/2015 01:32:36 PM" sw_rev="1r04i" svn="8521"/>
<registration sn="JNKCQB4-6" status="0"/>
<cal_id PCM="04896405AQ" CM1="04896395AFke0r0"/>
<restore id="0" vin="2C3AA63H55H162039" bc="13"/>
<system_db info="1r01b" dtc="1r01a" vin="1r01e"/>
<db mfr="DCX" tune="1r01e" pid="1r01b"/>
<db mfr="FORD" tune="1r01z" pid="1r01b"/>
<db mfr="GM" tune="1r02o" pid="1r01a"/>
<license avail="1" tuned="1">
<tuned vin="2C3AA63H55H162039"/>
</license>
<updates count="6"/>
<oem tool_oem="DIABLO"/>
<reg reg="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"/>
</tool_info>
Thanks!
tylerfegan wrote:I have tried to register a couple times and have heard nothing back. Could I get my device registered here is my info.xml
<tool_info>
</license>
</tool_info>
Thanks!
save this to the intune drive and it will be registered.
_registration.itf
(387 Bytes) Downloaded 267 times
