Windows 10 problems
Posted: Mon Aug 03, 2015 5:19 pm
by beachking2000
Having issues with dataviewer not connecting to tool in windows 10.
Re: Windows 10 problems
Posted: Mon Aug 03, 2015 5:44 pm
working on a fix.
Posted: Tue Aug 04, 2015 9:43 am
Here you go.
Posted: Wed Aug 05, 2015 11:46 pm
by beachking2000
works thanks.
Posted: Thu Oct 01, 2015 7:13 am
by Dragon23
So should I select to fix C++ or repair still not connecting
Posted: Thu Oct 01, 2015 10:05 am
make sure the driver is installed?
This software has been tested quite a bit and works fine with win10.
Posted: Fri Mar 18, 2016 6:51 pm
by brod10
Would this also work on the predator?
Posted: Mon Aug 29, 2016 4:54 am
by zaktech
Data Viewer still hangs on "Searching for a connected tool" (3.3.0.16)
uninstalled / reinstalled same problem
Win 10 sees the I2 without and problems
Posted: Mon Aug 29, 2016 5:08 am
by zaktech
Device manager reports the following for the I2
Windows cannot verify the digital signature for the drivers required for this device. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source. (Code 52)
Posted: Tue Aug 30, 2016 4:44 pm
uninstall the current drivers through the device manager then load the driver here:
http://installers.diablosport.com/softw ... er_2.5.exe
Posted: Wed Aug 31, 2016 2:19 pm
by zaktech
Already done that three times.
Downloaded the usb 2.5 drivers from your link, but can only test tomorrow, but I see the digital signature date is the same as I have previously used. (22 October 2015)
