Tuning causes Oil Change Reset
its really annoying that using the tuner causes my oil change counter to reset. it happened a while back when i first tuned the vehicle, and then now again when i returned the stock tune!! now i have to listen to the oil chime every time i start my car. its real annoying. Please fix this!!!
Re: Tuning causes Oil Change Reset
what vehicle are we discussing here?
Can you please post the current info.xml file from the intune drive?
The vehicle is a 2011 Dodge Durango Citadel with HEMI. I will post the file when I get home this evening
here is the file you asked for...
Mikel, i posted the file you wanted to look at... can you please look at it and tell me whats going on
this is something we are investigating.
+1
Happens on the 2011 charger too
This happens on my Wrangler also. They only thing I could think of was my original backup was taken when the oil change warning was set and when I get a tune based on that backup from my CMR tuner (whenever he makes changes) then the oil warning is set again.
soldier1326
Also on the 2013 Dodge RAM too
- D3-Blk-Hemi
Happens on my 2012 Durango Hemi as well.
'22 Durango Blackout R/T+
2012 Challenger also
Mikel what is the latest on this issue? I had a post on this last year that went unanswered. I took my 2014 Ram 5.7 back to stock tune yesterday and it changed the percentage from nearly 100% (I did oil change Saturday) to 11%. Very concerned about the ramifications if Chrysler is seeing this.
