2014 5.3 chevy
Egoresb
2014 5.3 chevy
Post by Egoresb »
Has a fix been released for the 2014 GM trucks 5.3L with 6 speed tranny regarding the banging shifts at WOT yet? Haven't seen anything on it in a while. Or is it still under investigation?
Would really like to use my in tune again without fear of my transmission falling out from under me.
Re: 2014 5.3 chevy
We have yet to be able to replicate this in house on ours or any other truck, really need to see whats happening.
Egoresb
Re: 2014 5.3 chevy
Post by Egoresb »
Is there anything I can do on my end to get this resolved? I've tried the back and forth emailed tunes to try and clear it up. Maybe a video or are there any other parameters that I can log to see what's happening?
I've already ruled out axle wrap with a go pro under the truck and I even borrowed adjustable traction bars. The bang feels similar to that happening. Like the springs would be loading up while power is being applied and unloading as the power band drops(as soon as it shifts) giving it the bang feeling.
The only other option would be to take my truck to y'all and have someone physically put it through the paces. It wouldn't be hard to duplicate as it happens at every shift point during wide open throttle in all conditions(weather temp outside and hot/cold tranny temps)
Egoresb
Re: 2014 5.3 chevy
Post by Egoresb »
The truck is 100% stock. Factory tires no lift. The only thing done to the truck was a k&n drop in replacement filter that probably needs to be cleaned by now. Also the tune I have been trying to run is the 89 octane tune +15% throttle boost and no changes in the tcm tune. Although it does seem to replace the factory tcm tune with what I'd assume to be a modified factory tune to correlate with the pcm tune.
Egoresb
Re: 2014 5.3 chevy
Post by Egoresb »
Or is it possible that my pcm/tcm may need a dealer software update to correspond with the current tune changes?
Re: 2014 5.3 chevy
Egoresb wrote:Or is it possible that my pcm/tcm may need a dealer software update to correspond with the current tune changes?
post your info file and I will check that.
Egoresb
Re: 2014 5.3 chevy
Post by Egoresb »
Ok I will do that as soon as I get home tonight. You should see it up Monday I would assume. Truck hasn't been to the dealer in about a year or so after my 24k tune up/oil change warranty ran out. I've been doing all the maintenance myself.
If that were the case hoe would I go about getting the stealer ship to update the software?
Egoresb
Re: 2014 5.3 chevy
Post by Egoresb »
went ahead and updated the tool again. reinstalled to truck just to see if something was tweaked and possible fix. with no luck. I also tried firm shift also didn't help. I have all tunes listed along with info file and a datalog I made. hope this helps resolve the issue.
TCM_24271132_LastTuneWritten.grg
(53.32 KiB) Downloaded 315 times
TCM_24271132_Backup.grg
(53.27 KiB) Downloaded 258 times
info.xml
(2.42 KiB) Downloaded 369 times
ECM_12659743_LastTuneWritten.grg
(112.25 KiB) Downloaded 294 times
ECM_12659743_Backup.grg
(111.32 KiB) Downloaded 360 times
3GCUKRECXEG170985_06.log
(691.78 KiB) Downloaded 261 times
Egoresb
Re: 2014 5.3 chevy
Post by Egoresb »
Anything?
Re: 2014 5.3 chevy
Everything in the TCM is current, let me check the PCM....
Re: 2014 5.3 chevy
All PCM cals are current as well.
Egoresb
Re: 2014 5.3 chevy
Post by Egoresb »
So everything looks correct. What's the next step to figuring out this issue?
Re: 2014 5.3 chevy
lower the throttle boost setting to 10% or less..
Egoresb
Re: 2014 5.3 chevy
Post by Egoresb »
Tried 10 5 even 0. All have no effect on the banging shifts at WOT
Re: 2014 5.3 chevy
if you skip tcm or load modify stock tune, how does it shift?
