Page 1 of 4
2014 5.3 chevy
Posted: Thu Oct 15, 2015 11:59 am
by Egoresb
Has a fix been released for the 2014 GM trucks 5.3L with 6 speed tranny regarding the banging shifts at WOT yet? Haven't seen anything on it in a while. Or is it still under investigation?
Would really like to use my in tune again without fear of my transmission falling out from under me.
Re: 2014 5.3 chevy
Posted: Thu Oct 15, 2015 12:29 pm
We have yet to be able to replicate this in house on ours or any other truck, really need to see whats happening.
Re: 2014 5.3 chevy
Posted: Thu Oct 15, 2015 2:56 pm
by Egoresb
Is there anything I can do on my end to get this resolved? I've tried the back and forth emailed tunes to try and clear it up. Maybe a video or are there any other parameters that I can log to see what's happening?
I've already ruled out axle wrap with a go pro under the truck and I even borrowed adjustable traction bars. The bang feels similar to that happening. Like the springs would be loading up while power is being applied and unloading as the power band drops(as soon as it shifts) giving it the bang feeling.
The only other option would be to take my truck to y'all and have someone physically put it through the paces. It wouldn't be hard to duplicate as it happens at every shift point during wide open throttle in all conditions(weather temp outside and hot/cold tranny temps)
Re: 2014 5.3 chevy
Posted: Fri Oct 16, 2015 9:25 am
by Egoresb
The truck is 100% stock. Factory tires no lift. The only thing done to the truck was a k&n drop in replacement filter that probably needs to be cleaned by now. Also the tune I have been trying to run is the 89 octane tune +15% throttle boost and no changes in the tcm tune. Although it does seem to replace the factory tcm tune with what I'd assume to be a modified factory tune to correlate with the pcm tune.
Re: 2014 5.3 chevy
Posted: Fri Oct 16, 2015 12:05 pm
by Egoresb
Or is it possible that my pcm/tcm may need a dealer software update to correspond with the current tune changes?
Re: 2014 5.3 chevy
Posted: Fri Oct 16, 2015 2:47 pm
Egoresb wrote:Or is it possible that my pcm/tcm may need a dealer software update to correspond with the current tune changes?
post your info file and I will check that.
Re: 2014 5.3 chevy
Posted: Fri Oct 16, 2015 2:56 pm
by Egoresb
Ok I will do that as soon as I get home tonight. You should see it up Monday I would assume. Truck hasn't been to the dealer in about a year or so after my 24k tune up/oil change warranty ran out. I've been doing all the maintenance myself.
If that were the case hoe would I go about getting the stealer ship to update the software?
Re: 2014 5.3 chevy
Posted: Fri Oct 16, 2015 7:58 pm
by Egoresb
went ahead and updated the tool again. reinstalled to truck just to see if something was tweaked and possible fix. with no luck. I also tried firm shift also didn't help. I have all tunes listed along with info file and a datalog I made. hope this helps resolve the issue.
Re: 2014 5.3 chevy
Posted: Mon Oct 19, 2015 5:43 pm
by Egoresb
Anything?
Re: 2014 5.3 chevy
Posted: Mon Oct 19, 2015 6:05 pm
Everything in the TCM is current, let me check the PCM....
Re: 2014 5.3 chevy
Posted: Mon Oct 19, 2015 6:07 pm
All PCM cals are current as well.
Re: 2014 5.3 chevy
Posted: Mon Oct 19, 2015 6:14 pm
by Egoresb
So everything looks correct. What's the next step to figuring out this issue?
Re: 2014 5.3 chevy
Posted: Tue Oct 20, 2015 12:35 pm
by 06MonteSS
lower the throttle boost setting to 10% or less..
Re: 2014 5.3 chevy
Posted: Tue Oct 20, 2015 1:25 pm
by Egoresb
Tried 10 5 even 0. All have no effect on the banging shifts at WOT
Re: 2014 5.3 chevy
Posted: Tue Oct 20, 2015 2:08 pm
if you skip tcm or load modify stock tune, how does it shift?
